Side Mirror LED Fitment
Random Poll
  • Total voters
    10
https://www.amazon.com/s?k=168+led+bulb+amber
Anyone have any experience with LED replacements that fit?
There doesn't appear to be a lot of depth room there; just enough for the "miniature" bulbs.
In the past, I've also had issues with the LED replacement base being too thick, to securely fit in the slot without damaging the socket/contacts.
Thanks.
EDIT:
OEM Light Bulbs:
https://www.fiestastforum.com/threads/ford-fiesta-st-bulb-sizes.1134/
Those do (barely) fit.
But they can pull your socket apart in the process of trying to remove them.
What were deemed as the interior LEDs, seemed brighter. So I used them instead of those that were deemed as exterior.
Recommend greasing the contacts down prior to insertion.
Here's the bulb size comparison...
https://1drv.ms/u/s!ABsZJDCN8kMMgaRc
These instructions simply don't work as they are totally incomplete. But the visual is partly useful.
Here are video instructions for gaining access...
View: https://youtu.be/Siot4Giaiuw?t=40
...BUT I would add the following notes based on my own experience.
* The tabs you press UP on with the flathead screwdriver do not fully release. They just sit near the edge of being released... no matter how much force I applied.
* Instead, you must partially release all of the tabs. They will all be sitting near the edge of release.
* Use https://www.bing.com/images/search?q=plastic+spudger+tool to press on the inside corner and pry from the seam, which will fully release that square clip.
* Then use the flathead screwdriver to punch the inside-most tab; all will then release.
* Be ready to catch the mirror housing before it hits the pavement. (and scrapes it up)
@TyphoonFiST - Thanks.
Also, in case anyone may be wondering about hyper flashing, it's not an issue with the mirror indicators. Whatever can be used.
danbfree
This is good to know as I avoided LED blinkers due to the complexity and heat of resistors, it wasn't worth it but since you provided this info I went ahead and ordered the sequential mirror blinkers from AliExpress!
