rear camber on fiesta st
Did you test with the rear dust shields?
I'm interested either way, but I somehow still have the dust shields up front with the V-Maxx brake kit and I'd like to keep them in the rear, too.
Sent from my H8314 using Tapatalk
I have not had time yet to put a set on my car. I am trying to get to it this coming week . Though I also have a local guy in Chino who is getting a set so it will be race to see who gets theirs on first . lol
kivnul
I am up for a set once you list them.
Well I will take pics and list tonight then.
kivnul
Don't rush on my account: I won't be installing until winter is over. Like my BBK, I figure this is something I will have to put on / take off seasonally.
Woods247
oh no I am ready to sell now . I made 25 sets.
As soon as we're certain this won't effect the ABS sensors (or require modification to them), I'm in. Thanks for taking this on!
green_henry
I think the ABS sensor "issue" is a red herring. You only need to remove the ABS bolt to release the dust shield, and then you reattach it -- the sensor itself stays right where it started, and there's not enough deflection to make a difference.
Woods247
I think the ABS sensor "issue" is a red herring. You only need to remove the ABS bolt to release the dust shield, and then you reattach it -- the sensor itself stays right where it started, and there's not enough deflection too make a difference.
Let us know if your theory is correct after you’ve pushed them on track.
kivnul
It is amazing how much things move and flex, even things that you would think shouldn't.
green_henry
Fair point. I won't get back on the track until March, but even if there were an issue, does ABS in the rear even make a difference? I'm not sure I'd notice. Front, yes. Rear, not so sure
Woods247
I had problems with ABS after installing rear camber shims. I posted it somewhere here. You can track without it but I like knowing it’s there. Since then, I installed washers on the bottom two hub bolts and I’ve been running it like that all season with no problems. They’re creating a little too much negative camber though, which is why I’m interested in these shims. I’m redoing my alignment soon and will post the rear measurement. We didn’t put it on the rack after the ghetto washer mod so I have no clue where it sits lol. I just went straight to the track to try it out.
Edit: The adjustable shims I used are much thicker than these plates. They required a custom bracket for the ABS sensor. DPro’s shims shouldn’t need that. My guess is they’ll work just fine. I’m just not up for spending $100 to try again haha.
Got to honestly say these things are literally sandwiched between your hub carrier and your beam with 4 bolts torqued down. If that stuff was going to move it would move stock. plus the holes are not slotted so how can it move?
I also think he is right about just reseating the abs sensor bolt. plus if there was going to be deflection aka movement in the sensor again it would happen stock. His theory is pretty solid IMO. Again the abs sensor bolt is not sitting in a slotted hole. So movement would not be an issue. Also you are spacing the sensor bolt not the sensor.
I will be putting a set on my car shortly not sure how soon it will be till I get to the track though.
Interesting so these shims were on the top only and not across the complete carrier surface? How much negative camber were the shims supposed to give? I do think that the shims only on top was what caused your issues.
Woods247
#33
They spaced the entire hub out. I’ll see if I can find a photo. You can clock them to increase/decrease camber. Cool idea but too thick for our ABS setup.
Edit: These are the ones that didn’t work.
#34
interesting can almost see why they did not work.lol
