Tried to turn her over last night to cycle oil and well.... One solid click from the starter. I've swapped relays and fuses from I believe r51 and f36? Whatever the manual says starter relay and solenoid are in the manual and no go... I think my starter died. I've checked grounds too. So I saw there's 2 grounds that wire to the main harness and then looks like one ground wires from where the starter wires come out. All of those are hooked to the block right now. Battery is grounded to frame and it's been hooked to a charger/maintainer the entire time the cars been out of commission. Battery is reading 12.6v so I don't think it's that. What do you guys think? I did clean the starter with contact cleaner because when the engine went kapoot it soaked the engine bay with oil. Maybe that shorted it? I did arc off the ground once on accident but I didn't think it was bad enough to burn up a fuse cuz it just grounded from one part of the block to another. Also when I tried to fill brake fluid into the slave it leaked haha. When I switched slaves I didn't notice the missing o ring (it got stuck in the old slave). So clutch is still unresponsive. Got new lines coming in for that should be here Friday.
