Konig has a container coming end of april / early may with a large batch of wheels. I inquired about a set for my FRS and was told this. However could be delayed due to the COVID situation
I need 15’s so I have a set of fairly new black Dekagrams available with Tires if someone near Phoenix AZ is in need... have 225/45R16 and prefer smaller diameter 225/45R15 for lower CG and maintaining some sidewall. Suggestions welcome for 15’s
I just got my SC2's put back on as things are starting to warm up in PA and I had inspection/emissions testing. Last year's front's were around 4-5/32 which is at the limit and this years front's (last years rears) are around 7-8/32. That was only about 6000 (max) miles of daily driving and no track events (unfortunately). I'll probably wear these out this summer and then have to start shopping for new warm weather tires for next year. The winters are shot (two seasons, as well) too, so I need to buy those.
I was happy with the SC's but would like to try something else. I like the 215/45/R16 size the ST1's come in but could try 205/50 Indy's. They are the two on my list, unless something else gets released in the mean time.
IF he is speaking of the 16" version, and not the 15" one.
225/50-15 is the size I would use on a 15x8 Pro Race 1.2 wheel, if I ever decided to go that route, and they should fit fine.
I would give up some of that razor sharp turn-in for a bit more side wall cushion against the shitty roads around here.
