Fiesta ST Weights Thread
Fiestig
I had posted to a previous weight thread, But I think it was more specific to weight savings for track since it was in the wheels & tires section.
If you have the weight of a specific part, post it or pm me with it and I will add it to the list. Since I couldn't find a general weights list, Hopefully this helps a lot of people find the weight info they are searching for.
FIESTA ST WEIGHTS:
OEM 1.6 Ecoboost Engine (DRY): 251lbs
OEM Crash Bar: 19.2lbs
OEM Downpipe: 8.16lbs
OEM Differential (including bolts, bearings, races) No ring gear: 9lb 8oz
OEM Motor Mount Passenger: 2.12lbs
OEM Transmission Mount: 2.15lbs
OEM A/C compressor: 13.4 lbs
OEM A/C Lines: TBD
OEM Condensor: 4.7 lbs
OEM A/C drier: 1.2lbs
OEM Radiator: 8 lbs
A/C delete bracket with pulley: 0.7 lbs
OEM 17x7 ST Wheel: 23.2lbs
OEM Bridgestone Potenza: 20.2lbs
OEM Full Size Spare Wheel/Tire: 36.4lbs
OEM (Non-ST Fiesta) 8 Spoke 15x4 Aluminum Spare Wheel/Tire: 19.2lbs
OEM Jack: 5.9lbs
OEM Battery: 26.4lbs
OEM Intercooler: 4.1lbs
OEM Intercooler Piping: 3.1lbs
OEM Hood: 25.2lbs
OEM Fender: 3.1lbs
OEM Bare hatch (Hatch & Glass only): 33.4lbs
OEM Rear Wiper assembly: 2.18lbs
OEM Wing: 5.84lbs
OEM front rotor and caliper 26.8lbs
OEM Steering wheel airbag: 2.5lbs
OEM Center console: 9.3lbs
OEM Strut Mass Damper: 1.2lbs
OEM Sunroof Glass/Motor/Tracks: 21lbs
OEM Front Caliper: 9lbs 2oz
OEM Rear Caliper: 5lbs 9oz
OEM Water Pump Pulley: 1lb 0.5oz
Driver Seat NON Recaro: 42.8lbs
Passenger Seat NON Recaro: 40.6lbs
Heated Recaro seat: 49.7 lbs each
Rear Seat Back 2/3 (w/bracket): 32lbs 9oz
Rear Seat Back 1/3 (w/bracket): 17lbs 10oz
Rear Seat bench pad: 8lbs 15oz
FIESTA ST AFTERMARKET WEIGHTS:
Batteries:
Antigravity ATX-20 Battery: 3.1lbs
Bumpers/Bracing:
TB Performance Crash Bar (Bare w/no tow): 13.6lbs
Mounts:
Vibra-Technics Passenger Motor Mount (Fast Road): 3.13lbs
Vibra-Technics Trans Mount (Fast Road): 3.8lbs
Brakes:
Wilwood front BBK caliper and rotor: 15.8lbs
WaveSpec Front Rotor: 13.5lb
Wheels:
16x7 Rota Slipstream: 14.12lbs
16x7 Enkei RPF-1: 13.6lbs
16x8 Konig Dekagram: 14.54lbs
16x8 Enkei RPF-1: 14.8 lbs
17x7.5 Team Dynamics Imola: 21.5lbs
17x8 Rota Grid: 18.9lbs
Tires:
205/45/16 re71-r: 19.5 lbs
205/50/16 Firestone Indy 500: 21lbs
205/50/16 Toyo R888R: 22 lbs
205/45/17 Potenza S001: 18.8lbs
215/40/17 Federal 595: 20.12lbs
Suspension:
Bilstein B6 Strut: 8.4lbs
ISC front coilover with Triple S spring upgrade: 11.7 lbs
Seats:
Planted driver passenger seat bracket: 8.1lbs
Planted passenger seat bracket: 7.1lbs
Sickspeed Suzuka racing bucket: 15.1lbs
Sickspeed Suzuka racing bucket mounts: 3.3lbs
Sickspeed Suzuka racing bucket sliders: 6.6lbs
Intake/Intercooler
Mishimoto intercooler: 11.2lbs
Cooling:
Mishimoto radiator - 12.12lbs
Engine:
Pumaspeed Uprated Lightweight Water Pump Pulley: 8.7oz
Exhaust:
MAPerformance Catback:
- front section: (missing weight)
- center section (s-bend): 3.1lbs
- rear section: 14.6lbs
- hardware: 3lbs
Exterior:
- SEIBON Hood Carbon Fiber RS-Style (WITH LINER): 15.14lbs
- SEIBON Hatch Carbon Fiber (Hatch and Glass only): 20.1lbs
Fiestig
Fiestig
Thread Starter #2
I know there are a few things that probably won't get the weight of anytime soon.
Des anyone have these weights on hand?
- AC Compressor
- OEM Downpipe
- OEM Strut
- OEM Axle
- OEM Diff
Yes, I'd like to know what a full delete of the AC system (at least the condenser, compressor and all of the hoses/piping) would save in pounds as well. [wink]
Of course, then you would have to add back in the weight of the AC delete bracket and pulley.
CarGuy
I would venture to guess at less than 30 pounds and closer to 20. Not as much as you think.
I've got the 16" Konig Dekagrams and they weigh 14.54 lbs each. Firestone Indy 500s in 205/50/16 weigh 21 lbs each.
Fiestig
Fiestig
Are those the 16x8's?
Fiestig
Fiestig
updated
Fiestig
Fiestig
Added some weights
Fiestig
Fiestig
ADDED:
- OEM Hood
- OEM Bare hatch (Hatch & Glass only)
- OEM Rear Wiper assembly
1.6
Very useful info. Does anyone know how much the sunroof adds? Any guesses?
I think our sunroof is close to 70lbs for the mechanism + glass.
At the very highest point of the car, ONE reason why I avoided it like the plague on this car (possible leaks/rattles/busted motors are the others). [wink]
Business6
Given the leak/mold issue myself and others have had/are having I wish I avoided it as well.
Fiestig
Fiestig
Updated with OEM Downpipe weight
Business6
"OEM Bare hatch (Hatch & Glass only): 33.4lbs"
The hatch is less than half the weight of the sunnroof assembly?
I remember reading a manual stating something like that about the weight but user experience says 30-40lbs. The track is usually steel components and there's nothing lightweight about its construction.
haste
Yeah....I find it hard to believe the complete sunroof assembly is over 70lbs.
I am about to go weigh the stock open diff so we can add it to the list. Great thread.
