Wilwood BBK F+R wheel fitment
To anyone running the 12.2”/11.75” rotor wilwood kit: I would like to gather info on what wheels work with it.
Please post what wheel you have successfully fitted (or those that don’t)and any details on spacers/modifications etc. that you needed to make them work.
Stock Fiesta ST 17x7: clears everywhere, but the front caliper is very close to the spokes. It probably wouldn’t hurt to shim/cheat the caliper inboard slightly to maximize clearance there. (Or maybe run a thin spacer if you really need to, mine didn’t need it) E12E596B-B511-4EEB-A8B4-A7A187F2414E.jpeg 9F7E5719-ED62-4DCC-8037-88043B191490.jpeg
Sparco Terra 16x7+42: clears everything, but if you have weights on the inside just behind the spokes on the rear wheel, they will have to be relocated because the caliper will just hit them AEE86FC1-B8B6-4AEE-9DC8-9A1EA72F4554.jpeg 44FBEFF2-3974-4B7A-A76E-642DD2CF7A06.jpeg
Enkei RPF1 16x7+43 4x108: fronts will clear, with 8mm spacer, rears are not even close. This wheel is about 14.25” inside diameter, pretty close to the 15” steelie spare that comes with the car
Team Dynamics Pro Race 3 (17x7 +38) - clears with lots of space, no modifications needed.
Konig Dekagram (16x8 +40) - also clears, wheel weights get close but do not touch, maybe 1/4" clearance.
This is just for the front kit, I dont have the rears.
Regarding RPF1 - I wonder if the 16x8s OAKOS has planned will fit without the use of spacers? Hope so
17x8 6ULs fit with lots of room to spare on the front. I don't run Wilwoods at the rear.
Any pics of it with these on (guessing that they are an open track setup [dunno])?
Believe it or not, I actually do really like the aesthetics of the 17" diameter and up 6ULs LOL, just not the looks of the very short spoked, 'they will float up to the sky like a hot air balloon without tires on them' zero gravity, 15" versions. [wink] [thumb]
