- Member ID
- #10195
- Messages
- 53
- Likes
- 23
see now here you give some evidence do you have any dyno charts for it? Plus its interesting you mention the stock turbo feeling more responsive below 3k because from the dyno charts I read the S280 has a 50ftlb tq dip in the 2k-2500 range. after that it pretty much followed the stock TQ curve line till around 3k and then took off vs the Whoosh that shot like rocket on up the dyno chart right around 2k-2500 and turned over hard and started dropping vs the gradual constant upwards bell curve of the S280. Essentially on the charts the Whoosh peaked way earlier than the S280 on TQ .The S280 had much more linear curve on both TQ and HP which means that it pulls like a freight train above 3k and actually does need extra fueling to take full advantage of what it is capable of delivering. I talked to my tuner who does not like aux fuel as they use a piggyback system from the 90’s. Which is completely true. They favor a HpFp and possibly injectors,.
I drove a Whoosh and noticed the massive TQ in the low end the car pulled like crazy right off the line.
The argument one usually gives for that is tire spinning on the low end does no one any good except are you losing that low end pull on the s280. Most have claimed its fine a few have said they noticed the difference compared to their previous hybrid ( x47) .
So that is why I was interested in the differences between it and the Whoosh.
Which you came in and shit all over my post with your opinion and not fact and proceeded to argue about.
In the end the truth comes out you have never had a hybrid have a s280 and even mentioned the fact that you noticed the TQ dip.
HMM egg on your face time.
Sent from my SM-N986U1 using Tapatalk
