16x8" RPF1s ARE IN STOCK! ~ ORDER NOW!
Trader history for OAKOS Automotive (0)
^^^Yeah, THAT size should have NO fitment problems whatsoever, regardless of ET/wheel width, or ride height!
I want to see a set of TALL and wide tread width 225/45s on them, and no rubbing. [wink]
Jabbit
New England
#42
Just got my set in the mail a couple days ago. Considering buying 245s and cutting the car up to fit them. On stock suspension right now but planning for coilovers ASAP. Edit - considering Toyo R888R in 245/45/16, any thoughts?
Salt Lake City
#43
- R888r run really wide so check the actual width of the tire.
- R888r are sketchy in the rain so keep that in mind
- If you plan to do any time of AutoX you'll be knocked up to the top class because of 100TW
- 245/45/16 could fit on this car but with those wheels and ET it'll poke
I'd suggest looking at RT660, RE71R or something else in the 200tw range. But I also have a negative opinion of the R888r so take what I said with a grain of salt.
Jabbit
New England
#44
Thank you for the advice. The re71r comes in a 225/50/16 and was hoping to get wider. Don't really care about rain and I don't auto-x, just full track days so no worry about classes either. What do you mean when you say poke? I will likely be running some sort of fender flares as well so I can keep it street legal.
^^^I believe that Jabbit is building a full-on race/open tracking car, and plans on flares huge enough to cover all of that 'poke'.
But even with all of the cutting/butchering of the fenders, and those flares, he probably would not be able to lower the car as much as he would (probably?) want and still not rub on full compressions of the suspension, with a 24.6" tall tire, no matter how stiffly sprung. [wink]
Jabbit
New England
#46
Thanks for the reply. So with these cars it seems like height is more of a concern than width? I'm thinking some CAD (cardboard aided design) is in order here to see what really fits. But now to decide - is a lowered/stiffer suspension with "small" tires better than a slightly taller suspension with "wide" tires? Edit: Also whatever rubs on this car is going to get cut off, assuming I can keep the car road legal and structurally sound.
ronmcdon
Beverly Hills
#47
I got a set of these wheels too, stock suspension, -1.8 front camber, stock rear camber and played it safe with 205/50/16 Dunlop Z3's without any rubbing.
Ideally would have been happy to get 225/45/16, Dunlop Z3's on instead but was not sure it wouldn't rub even with fender rolling and pulling. Hope I'm wrong.
Those are still a full half inch shorter than the 245/45-16s. [wink]
ronmcdon
Beverly Hills
#49
Jabbit
New England
#52
73mm wheel side to 63.4mm car side.
I unfortunately only have plastic ones available right now.
Thank you for the reply! Will have my wheels on later this week and I'll post a picture here.
BTW for anyone considering working with OAKOS, I can't say enough good things about their customer service. Quick replies to emails and friendly knowledgeable folks.
Central Valley
#53
Curious if you got any pics of these on your car?
Jabbit
New England
#54
I'm rebuilding a salvaged car so I don't have great pictures yet. Will take more once it's inspected and on the road. This is stock suspension with 205/45-16 re71r tires. I have ISC coilovers that I have yet to install. If you look in the builds sub-forum you can follow my thread there for more updates.
OAKOS Automotive
OAKOS Automotive
Vendor
Sterling Heights, MI, USA
Thread Starter #55
View attachment 38156 View attachment 38157
Hey we are also rebuilding a salvage car that will be getting the 16x8s when its done!
Jabbit
New England
#59
I put on some center caps from Flat Out Graphics. Not super cheap at $50 for 4 but I think they really complete the look of the rpf1s better than the factory caps.
Agreed! [thumb]
Those look good!
I don't like very raised/deep, conical/trapezoidal shaped center caps, even though I had to use them (from Compomotive, no less LOL) on my Method MR401VTs, since they were the ONLY thing I could find which actually fit the outer center bore of those wheels.
(Being a rally 'competition' labeled wheel, Method did not even make/offer a 'factory' center cap for them, at all.)
