- Member ID
- #4150
- Messages
- 14,814
- Likes
- 7,275
What should I look at first in regards to the headlights not working?
Are there fuses as well as a relay for just the low and high beam headlights?
The DRLs/parking lights work just fine, but the headlights will not respond even to the manual switch, let alone not work on the auto setting I usually leave it on.
It would be highly unlikely to almost impossible that BOTH low beam bulbs (PIAA H11 Night Techs) would go burn at THE SAME EXACT TIME, correct (without a surge/spike/whatever blowing them both out simultaneously)??
It was too dark to check anything when I got home, (luckily without passing any cops), so I just want to know where to start tomorrow, besides pulling the lights out to get to the bulbs and checking those.![Wink [wink] [wink]](/images/smilies/wink.gif)
Does doing the 'master reset' on the touchscreen have any effect on the BCM (which controls the lights, correct??) at all, or is that only for the screen and audio system?
Should I try that as well?
Thanks in advance.
Thanks in advance.
