I have a 2018 FiST with an S280 and 50K miles. Last week in 94 degree heat and in stop and go traffic, I got the dreaded high coolant temp alarm, then quickly shut off the AC, maxed out the HVAC temperature and fan speed, and turned onto a side street to give some air flow over the radiator. Coolant temps dropped, but remained at about 220 until I got the car to higher speed, then it only dropped to 217.
The coolant fan fails to work regardless of ambient temperatures OR if the AC is on. Coolant level is fine. I checked the fan fuse, replaced the fan relay, but have yet to research/price the fan control module. The fan spins freely when the engine is off and I do have the 180 thermostat installed, but don’t think it is part of the problem. This morning, I’ll put the car on ramps and check the electrical connections on the fan control module. Am I missing any other simple check?
Ok, update. I put the car on ramps, disconnected and removed the fan control module. The connector which leads to the fan had one charred (positive) connector, so not sure if fan, control module or both had failed. Using a 12 volt power supply, to test the coolant fan, I connected the fan and it didn't work at all. To verify the fan module was functioning, I installed the module, but left the connector leading to the fan disconnected (smaller connector). I started the car, turned on the AC, and measured 14.4vdc at the terminals (on the module) which power the fan.
Tasca Ford shows a radiator fan assembly to cost about $250. Any leads on where to procure a used/or cheaper one?
Thanks,
Jeff
Thanks,
Jeff
(YES, I know that the Mishi shroud is metal/alloy, but it still uses our factory fan, correct??)
