Exhaust manifold studs
Going to install a ported exhaust manifold for my hybrid turbo ....anyone who has previously done this recommend changing out all the studs or any advice when doing this
ron@whoosh
Vendor
run a tap through all the threads to clean them (2 on manifold flange, 1 on the turbo flange)
install new studs or new bolts
tap and thread size for new hardware is M8x1.25
J
How about the ones that go on the block itself?
ron@whoosh
Vendor
If I have the exhuast mani off its getting new studs and nuts. It's the right way to do it
ive had stock, VUDU ported, whoosh extrude honed/ported/coated, and Peron tubular on the 2017 orange spice head , never had an issue with reusing the OEM studs and nuts in that area
The OEM manifold to head studs don't get stretched, so they're OK to reuse. Just make sure you hit them with the torque wrench prior to reinstalling the manifold to make sure they're tight. Replacing them can't hurt, however. I replaced all of mine while I had the manifold off.
MagnetiseST
I work at a dealer. If they come off, they get replaced. FSM >
Seconded. FSM says to toss them and install new studs / nuts. I have done both ways (replace and not replace) and have never had an issue, but the right way is to replace them.
The bolts are M8x1.25 but how long are they? I’m trying to find high quality studs to order.
akiraproject24
I actually emailed Ron on this yesterday. I ended up grabbing the ARP downpipe hardware times 2 for both ends of the turbo and as of now just grabbing a set of OEM manifold hardware just in case during install any of it gets mangled. I checked the ARP website and they got more for pintos than I could find for this car.
That’s crazy, I emailed Ron the exact same question but I think he’s had enough of my incessant questions haha, I also ended up just ordering rhe ARP studs from Amazon in M8x1.25 32mm length as that’s all they had. Hope they fit as I would really like to do this install correctly. Is that the same length you ordered??
ARP 400-8001 M8 x 1.25 x 32mm Stainless Steel Stud Kit - 4 Piece https://www.amazon.com/dp/B003TPMUFQ/ref=cm_sw_r_cp_api_glt_fabc_5HZKXDCXMBQ4N32XTV48
resurrecting this thread because i'm doing my turbo soon, and am looking at this kit, but curious if anyone has used it. i'd rather pay this at the same time i'm buying the downpipe rather than paying $12 per bolt at the dealer. and should i really worry about replacing manifold studs, too?
