Stock head lights
Looking at the Ford catalog, it lists 2 different light assy. for each side. one With complex reflex design. 2014-19, with reflect design. one with out, how do yo know which is which. The pic. is my car IMG_0021.JPG
Ask your dealer's parts department they will check the VIN of your car and give you the correct part number.
You can then buy from where you want.
Fusion Works
I'm going through this on my car right now. Just received two new lights from Ford and they have chrome trim around the lights. My 2016 has black trim around the lights (inside the lenses). I will get part numbers in the morning. I do remember being the most expensive model lights.
I looked at a regular base model type Fiesta at the grocery store tonight and it didn't have the chrome lights either, black just like my current lights.
Fusion Works
Old Mike Emerson
Figured out my car has the Spyder Black head lights, previous owner replaced them, add to the list of mods done before I bought the car. I will be buying the Spyder lights, I like them.
Fusion Works
What makes them better than the OE lights?
I prefer Depo or Hella,as they are oem reps.I had bought the spider ones and my Retrofitter tried opening it and it just started to crack everywhere.Went with depo and it opened without issues
Are ANY replacement headlights made for us yet which do NOT require a split open retrofit in order to use LED bulbs properly (i.e.; built from the get-go as LED lenses)? [dunno]
I had Cougar small's for the low beam and had to trim a little plastic off the pas side for it to fit properly.Still wasnt satisfied by the beam patter,so went the retrofit route
Old Mike Emerson
I don't need to open mine.
