Honda front strut install. Silicone lube?
akiraproject24
I'll be doing a full spring/strut replace on a honda and for those that have done this work before, Do you lube the rubber isolators and bushings with say a silicone lube like the type used for brake glide pins? I am pretty sure I should but dont want to create dust and dirt magnet areas on them.
Use a ....
WD-40 Specialist Dirt & Dust Resistant Dry Lube PTFE Spray with SMART STRAW SPRAYS 2 WAYS, 10 OZ https://www.amazon.com/dp/B00AF0ODGM/ref=cm_sw_r_apan_i_8BTAVVNV5HYAS456F56R
akiraproject24
akiraproject24
