Is turbo flutter with a Turbosmart EM BOV plumb back VR2 normal?
minieater
Hi,
I have a S280, tune, v3 intercooler and cold plugs as mods.
I checked the plug and vacuum several times and they seem to be correct.
Some people say flutter is normal with the bov and some say it's not.
Attached is the sound it makes. It's faint but still there especially with the window down.
Thoughts?
Thanks
Nothing to worry about. Also sounds great!
My understanding is that surge is what you're worried about, and you'll only see that problem manifest as you're rolling into power if present not as the turbo responds to coming off boost. And once you're off boost you're not in a situation where you even need to be worrying about noises, surge, flutter, etc.
the duke
Yes. It's partly the design of the system. my Kompact full Recitculating sounds the same.
M
minieater
Great thanks for the quick responses
Yarp. Same here. I wish mine was a little louder, haha.
Vent to atmosphere FTW on the noises! Even though it probably contributes to some lag between shifts.
haste
Yeah, I thought about it but my car is already loud enough with the exhaust. I didn't want the BOV noise on top of that. The odd thing is the frigging stock diverter valve was louder than the plumb back!
Can verify with everyone else that is normal. As other stated, you need to be concerned if you are coming from high boost, situations and you here a more violent flutter. That is when you need that BOV to clear charge pipe pressure.
MY GFB DV, even with the thick factory type Motorcraft filter, albeit in an ST200 box, 'chirps' loudly between shifts, especially when cold.
