- Member ID
- #10988
- Messages
- 761
- Likes
- 994
I was doing some wondering based on the junk I had laying around the shop today. Its always pissed me off that Suspension Techniques has either lied, mis-measured, miscalculated, or whatever the spring rate of their lowering springs. First they claimed 240/250 (this is the reason they bought them) I measured one of the rears and it was 117lbs/in. That is less than the OE springs by a lot. Today I measured the front and it was 135lbs/in. So much for their reputation and accuracy.
Well I got thinking when I tried to install the ST spring on the B8 damper. It required a LOT more compression to install the top hat than the original Ford strut. So I got to wondering about how much preload these were generating at installed height. Time to drag out the scales and other measuring apparatus.
With the ST spring installed on the Ford OE strut, I have 115lbs of preload. With the spring installed on the B8 (which is 1in shorter shaft length), I have 231lbs. As I ramp up the compression, There is quite the difference in actual force generated by the spring.
The OE Ford Damper with the ST spring generates 237lbs, 373lbs, 504lbs, 580lbs of force at 1-4in worth of compression.
The B8 Strut with the ST spring generates 357lbs, 494lbs, 629lbs, 754lbs at the same 1-4in of travel.
My Custom Strut with a 162lb spring generates, 387lbs, 547lbs, 711lbs, 873lbs with 1.4in of travel. In reality my travel indicator shows over the last few months, no more than 4.5in of travel. In my case I am not getting into the bumpstop.
When I installed the ST springs on the OE dampers, I was always suprised at how low the car sat and how much it rolled in the corners. Having the same spring on the shorter damper with the high spring forces, I will be interested to see how the car behaves.
When I get a chance I will check the OE Ford springs with bumpstops. I have to get an OE spring and damper from a friend. I recycled my OE springs last week. LOL.
