Raistron's Build thread
#41
That's entirely dependent on how we figure out the BCM, as I'd like to make it possible to keep all the stock functionality, heated seats, sunroof, etc etc, right now we've got a LSX with a roots blower and a t56 magnum hooked up and ready to drop in to whatever we'd like. But until we figure out the ECM-TCM-BCM shenanigans, it will languish with the V6 that's slowly tearing itself apart.
If it turns out we cant get the BCM to play nice, the most likely move is going to be picking apart a salvage GT and it's drivetrain in, modify it from there once it's running. At which point that LSX and T56 will be making its home in its second El Camino since we've owned it lol
Even LS2s and LS6es <-(IF you can find one!) mod up nicely, and then you do not have to worry about that pesky crank position sensor reluctor ring debacle
scenario. [wink] [thumb] [driving]
Raistron
Thread Starter #42
Well, had no choice but to get the wheels and tires today. Had a blowout on the interstate after a surprise pothole put a hole in the tire. So I've got a set of 5, 4x108 16x8 Enkei RPF1s coming. Gonna wrap them in 215/45r16 RT660's and see what we get out of it. Should be here on the 28th for the tires, not sure how long until the wheels get in, but bought two day shipping. Fiesta will probably stay parked till then cause I can't stay under 50 to get to work, and it was sketchy getting back. Glad I ordered the full size spare wheel and tire.
Unrelated to the Fiesta, the G8 grenaded the 3.6, so it's getting a 6.0 likely from a wrecked G8 GT.
#43
I was just looking on the Mast Motorsports site to see if they still had some lower power/less modded LSxes you could use in the G8, and HOLY S**T did their prices ever go up exponentially since I was considering one of their crate engines (to replace the dropped lifter LS1 in my '00 Z28), 8 or so years ago!! [crazyeye][ohcrap]
Raistron
Thread Starter #44
Part of why we'd use the existing one we've got, but we've yet to figure out the BCM, hence the thought process of getting a wrecked GT. We'll see about that though, so many projects, so little time.
Raistron
Thread Starter #46
New wheels and tires are on, that's the fitment, less than in inch clearance in back so trimming will definitely be needed. Definitely gonna go with some fender rolls and taller tires in the future, need to fill that gap with thicc tires
#47
FWIW, negative camber could get you where you need to be with fender clearance. a lot of people here buy @Dpro camber plates to get the back tires to around -2 camber (i think); it's a handling mod but the added benefit is rear fender clearance. if you wanted to do it up front you'd need to get camber bolts and/or a new adjustable top hat for you strut. camber bolts are a lot more straightforward but top hat is a lot more stout/OEM.
Raistron
Thread Starter #48
Good to know, I'll look into this and see if it will be enough. Especially knowing I have intentions of going to a taller tire in the future, if it fits, it ships.
Raistron
Thread Starter #49
Did the oil yesterday, doing transmission fluid today. Got 2l of ravenol 75w-80 for it. Gonna see what I get out of it.
Raistron
Thread Starter #50
Got about 1.6 liters from it, not a perfect science but I know what was in there
Raistron
Thread Starter #51
Took 2 L of ravenol without spilling any, tried to measure as I've seen in the manual (20mm from the fill hole I think?) Was on a lift so it wasn't too hard, but frankly it was too hard to tell, but the fluid wasn't close to the fill hole even with the extra .4 of a liter in there. Shifting *felt* smoother, but could honestly be placebo. Will be driving 300 miles to the Magic Dragon car show tomorrow, so we'll see how it feels then.
Raistron
Thread Starter #52
Took the 150-200 mile drive all backroads with constant shifting. I'm thoroughly convinced that it didn't have enough fluid in it before. Shifting is now buttery smooth, and silent, used to make very light clunk sounds.
Unrelated, but ordered all of whoosh's metal boost hoses, saw some knicks on one of the plastic pipes that I didn't like the look of so I ordered the whole set. As well as weather tech liners and the window protectors.
Raistron
Thread Starter #53
Got all the piping installed minus one that I believe is on backorder. Weathertech stuff is top notch, especially the window liners!
The Fiesta also got a big brother today in the form of a 2014 Taurus SHO that's replacing the wife's Hyundai. Likely to replace the G8 as a long trip car as well, given the heated and cooled seats, sunroof and all. 20230523_182712.jpg
#54
Those are kind of rare, as I do not believe that I have ever seen one out and about in 'the wild'. [thumb]
Raistron
Thread Starter #55
Neither have I, actually. It's absolutely faster and more comfortable than the Fiesta, but nowhere near as fun. I prefer being able to step on it and not be in felony territory in less than 5 seconds lol
#56
suggest you don't install an aftermarket turbo on the fiesta then...:sneaky:
Raistron
Thread Starter #57
It's been a while, and sadly I only have bad news to share. The Fiesta was hit while the girlfriend was driving it while running errands since I had borrowed the Taurus since she didn't work that day. Minivan decided to gun it into traffic and smashed into an Equinox, and knocked them across three lanes of traffic into the Fiesta. No one was seriously injured, but the Fiesta is likely totaled out. Oil cooler was punctured and the radiator is toast. The engine -might- be ok, but I will likely let the insurance company take the car with the total out settlement. On the plus side, the insurance allowed me to put the stock wheels and tires, tail lights, and swap the shift knob as well before they inspected it for the total out settlement. So I will likely have all of that listed for sale once the verdict comes down.
On the bright side, I still have my pickup and G8 GT to drive, but I'm definitely going to miss my little bean, it was a blast, and I'm gonna miss it.
received_1131604865449490.jpg received_685142144409599.jpg 20250611_102243.jpg 20250611_102234.jpg 20250611_102231.jpg 20250603_150646.jpg 20250603_150640.jpg
#58
View attachment 66801 View attachment 66802 View attachment 66803 View attachment 66804 View attachment 66805 View attachment 66806 View attachment 66807
Ah what a bummer. Important part is no injuries, so I’d call that a win.
Raistron
Thread Starter #59
Agreed. The car did the most important job it has, protecting the people I'm willing to let drive it, so all in all, 10/10.
#60
My wife is terrified to drive my car because she knows how much I love this car and is afraid of this exact scenario. I tell her all the time to drive it anyways. No dice in 8 years of ownership lol
