Pros and Cons of the Fiesta's Radiators
FiestaSTdude
I'm looking for a upgraded radiator for my Fiesta, because now that I have AC, I'm seeing temps that are higher than I'm comfortable with. I want one that's relatively affordable and fits without too much hassle. The Whoosh radiator is out of stock currently. I've heard lots of good things about mountune and I'd definitely be opened to that even though it's more pricy. What are y'all's thoughts on what I should get?
FiestaSTdude
FiestaSTdude
Also I just found a Koyo radiator for $544 . . .
eBay radiator (mishimoto clone) is the cheapest option but you have to do some fabrication to mount the fan shroud. It actually runs 1 degree cooler than the name brands. I helped install a buddies mountune radiator. If you want some more info let me know and I'll gladly help.
Capri to ST
I had a Koyo radiator on another car, and it fit perfectly and was of high quality. However, I remember reading somewhere that somebody had some issues fitting a Koyo radiator to our car, but I can't remember where I read it.
Mountune does offer discounts time to time. Currently that have a %15 off code. Mountune is who I would go with if I was buying one.
Capri to ST
I would grab the koyo. I think in the reviews on whooshs site it says the shroud fitting was "fiddly". A dude on youtube did a video on his and loved the results and didnt mention any fitment issues.
You're right, that's where I had seen the reviews saying that the fitment on the Koyo was a bit tricky-
https://whoosh-motorsports.myshopif...nflo-triple-pass-radiator-2014-2019-fiesta-st
I would agree with you that it's probably a good radiator based on my experience with it on another car.
rallytaff
I got the Mountune one after 7yrs of owning the car even though I'd had no problems with the stock one. I had them install it too.
Mountune and mishimoto both solid options. I went mountune because their stuff just fits up better than anything else.
FiestaSTdude
FiestaSTdude
Im kinda torn between koyo and mountune at the moment. They all seem to perform much better than stock though. Watching the coolant temp on the fiesta in the video makes me realize how much of a difference the upgraded radiator makes.
akiraproject24
I think you and the car would ultimately be happy with either one
FiestaSTdude
FiestaSTdude
Definitely! Im leaning toward Mountune just because there’s more info on it. Thanks everyone for the input, it’s nice to know that we have several good options
Dialcaliper
I’m definitely happy with my Mountune as well. Install was super straightforward although I did have to file on the lower brackets a bit as they ended up too narrow for my fan shroud tabs. The downside is it it took a really long time from purchase to ship because they ran out before they could update the “in stock” on the website.
I have the Mountune radiator and have family in Charlotte, NC. In mid August while pulling the steepest hills on I-81 the engine temperature never waivers from showing 4 bars. I will also note that after installing the Mountune 3 pass radiator my fuel economy increased by 4 mpg in the city and on the highway. Turns out that the 195 degree radiator supplied with the car is the IDEAL operating temperature for this engine. BTW, winter mileage in the city is not as good, these cars drink gasoline when the engine is cold and that larger radiator slows down the engine getting up to optimum temperature. As a result winter mileage is off by about 5 mpg versus summer city driving.
Tip for the Mountune radiator and this was learned from real world experience. The Mountune radiator is thicker than the factory radiator and as a result the fan shroud is moved closer to the engine. After installing the Mountune radiator look very closely at that fan shroud and make sure that it's not rubbing on any hoses anywhere. If you allow hte shroud to rub on a coolant hose at about 30,000 miles you will have a coolant leak and you'll also find the hose you need is NOT stocked at a Ford dealership. BTW, I used a bicycle tire patch and electrical tape to effect an repair while I waited for the new hose to arrive.
I was overheating and going into limp mode on the track with the stock radiator. I chose Mishimoto because it allegedly has the highest coolant volume of the aftermarket radiators, and I was looking to throw the best at the problem. In the end, it was probably irrelevant that it has a few more ounces of fluid.
The tradeoff is that you have to stuff it in. Mishimoto lists it as a 4.5 hour install, which was pretty close to true. Folks seem to be able to get the other choices in faster.
Jabbit
What basis are you using to say 195 is ideal? MPG or something else? Im running a mountune and I'm trying to keep temps as low as possible. Going to swap the thermostat too.
I am guessing that you meant the factory 195*F THERMOSTAT yielding the 'ideal temp' (for fuel mileage??), correct?
Yes, if/when I get around to doing an aftermarket radiator, those extra long Fram Ultra 3600 oil filters are going to become totally unusable (as they are a struggle now with the factory radiator/shroud as it is).
I just hope even the short, factory size filters do do become a problem, depending on the radiator chosen.
