I had a bizarre experience at last weekend's autox where I was trying out new set of RE-71RS in 215/45r16. The front pair running at 43 PSI (which I gather is a fairly high pressure) was rolling over onto sidewall in hard turns. Few years ago I was running the original RE71R and did not have this problem. Front camber is at -2 degrees which is more than I had with RE71R.
The only other thing that stood out is folks at the event commented about the amount of nose dive on the outside front corner during the turn. So now the question is whether the stock suspension is too soft or has worn out, allowing for extra flex, and what can be done about it. Someone suggested to install a rear sway bar which would theoretically make the rear rotate earlier before the tire collapses, however wouldn't that make the car unstable in slaloms? Camber bolts will likely allow for another half of degree but this seems like a bigger problem than that half degree can solve.
Has anyone gone through the same with their Fiesta?
