Damond Motorsports Fiesta ST Oil Catch Can kits
Trader history for Damond Motorsports (0)
#41
I just installed this OCC. Is it a PITA to open the drain valve? I'm not sure if I'm doing something wrong. Maybe my hands are just too big lol.
Doubt you're doing anything wrong, as I have little girl hands and It takes me some maneuvering to open the valve lol.
#42
😂😂😂 Thanks the laugh.
#43
I have Carni hands also.....No issues when I had mine. Don't DO IT AFTER DRIVING the FiST. Save your self some forearm burns*
Erick_V
#45
People like to give me crap for the way I do it but I have a ratcheting wrench so it’s easy for me to just remove the can and lines and prop it up to drain while I do an oil change. I also have large hands and I ran the hose down but it was still hard for me to reach up and hit the drain, I ultimately removed the tube and used the method above. Takes me 2 minutes tops to take the can out
#46
That's exactly what I was thinking I might have to do. I have large hands, so this might be my go to.
jayrod1980
#47
Can someone hook me up with the hose size for the drain? Mine fell off the car and is out on a road somewhere between my house and Indian Springs Nevada. I’m sure I could pick up some hose at O’Reilly.
xxiaze
#48
If you plan on picking up hoses from an auto parts store make sure that they are PCV or trans fluid lines OR silicone lines.... do not use heater/coolant plumbing. I did this and mine collapsed, had to source some PCV line. Was unable to source any in 5/8” ID at major auto box stores. Found mine at a smaller auto division but still local.
#49
^^^I'm not even sure that I would use silicone in this app, unless it was HEAVILY reinforced with a fabric/aramid/whatever layer. [wink]
#50
Are these hoses going to start seeping oil like the mishimoto hoses ?
jayrod1980
#52
Damond’s hoses are great. I had no issues at all with mine after 4 years, but I did remove it when I was searching for my boost leak. Turns out it was a 6 inch crack in my DHM intercooler. The hose I’m talking about is the drain line that only sees fluid when draining the catch can. I guess I’ll message Damond and see if they will sell me a replacement.
FiestaSTdude
#53
Is everyone still liking these OCCs? I just cleaned my valves and I figure I should probably put an OCC back on my car. Diamond looks like the best option. Anyone have issues with boost leaks or vacuum leaks? I like the mishimoto one too but I don't like the mounting location since there's a lot going on in that space. My previous OCC rubbed an AC line and took out my AC.
#54
It seems like the best OCC if you want to use one, but the validity of OCCs seems debatable ranging from pointless but harmless to pointless but potentially harmful. I personally have not and will not use one, as there's little compelling argument I've seen for them. But if I had to run one, it would be the Damond.
#55
Mine is still just fine as far as not having any leaks in the hoses/junctions/etc., and for the hoses not rubbing into anything under hood.
But the drain valve IS impossible to reach without getting up under a jacked up front end, and even then it takes some blind reaching around along the fire wall.
I cannot ever have this car up on a jack in my development, and since it is impossible for me to get to the drain valve and hose with the car on the ground, I like others in this thread, am going to have to remove the can to drain it, as it's been over a year since it's been done. [:(]
FiestaSTdude
#56
I bought one just to be on the safe side. I'll report back about how much it catches. It's not cheap so hopefully it does something to reduce buildup
Erick_V
#57
Still running mine also, believe I installed it in 2018. I usually empty it after pulling the drain plug and filter during oil changes. I think I get 1-2oz of fluid out every 5k. Would rather have it in the can vs on the valves.
jmrtsus
#58
Not a problem if you have a smaller hand............thankfully I do!
FiestaSTdude
#59
Installed mine today. Install was straightforward, I cut the hoses so they fit nicely and won’t rub anything. I also got the protective sleeves which unfortunately cover up my nice red hoses.
So far I’m happy with how it fits and the quality of the parts.
