Resetting Oil Light for vehicles with Cobb Tune
jmrtsus
Ooltewah
I have a 2016 and none of the aforementioned procedures worked for me, so I tried resetting the oil life via the AP, and that turned my wrench light off. Eh, go figure.
My 2016 has for its life up to now required per the manual to press and hold the start for several seconds. That no longer works, now you just push it to turn on......no hold! Go figure!
jmrtsus
Ooltewah
T.QUOTE="HardBoiledEgg, post: 461869, member: 7437"]NEWER ONES DON'T HAVE THE WRENCH LIGHT FOR MAINT
155K NEVER CAME ONECE, 2017[/QUOTE]
According to the Owner Manual the 2019 has one, so does my daughters '18 ST. My '16 ST comes on at about 10K intervals.
Green Bay, WI, USA
At work, gonna have to give you a proper response later. But off top of my head, you connect your Accessport and go to the oil life feature and select it and I believe it asks you to reset and you click yes.
XR650R
Eerie
I had no idea you could do that. Then again, mine's never come on. I change my oil every 5,000 because turbo.
Cobb sez:
  1. Go to the Troubleshooting menu on the main screen of your Accessport.
  2. Select scroll down and select "Reset Oil LIfe"
  3. Once you select it you should receive a warning message.
  4. When you're done you should see a message letting you know it was finished.
My wrench won't turn off.. so getting an AP can fix this?
Getting an Ap has a lot of benefits other than resetting the Wrench light* It allows for data monitoring via multiple gauges and the ability to get a Better than OEM Tune from a Tuner* [driving]
