I did a Fiesta ST Timing Belt, Here are my observations (and problems)
Suwanee
get the right kit. i'm buttoning up mine now and i've now gone through two (!) crank pulley holder tools. the first one was too long and was not removable once the pulley was snugged up, the other was the right length, but the tooth that holds the pulley wasn't long enough and i had to shim it with washers to get it to engage the back of the pulley. what a CF. how there can be that many poorly manufactured tool kits out there is astounding. the pulley removal tool also was the wrong size and i had to go get a 3 jaw puller to get the pulley off the crank.
this job is a real PITA. at least when i pull something apart it comes apart ok. the original belt looked good and isn't cracked. even the serpentine belt looks new at 146k miles. The axle seals though are done and i had to get more, which is delaying finishing the job, and i'm looking at a small amount of carbon build up in cylinders 1 and 4 that i'll probably do a cleaning on before the intake manifold goes back on. Cylinders 2 and 3 look really good fwiw.
Virginia
What kit name did you get? I need this done soon, but with the problems and difficulty described in this thread I think I’ll get a shop to do it. Thanks for the heads up
Suwanee
this one:
https://www.amazon.com/dp/B09NB6TCXK
its rubbish. the flywheel locking tool and the crank pin work though.
this is the only-slightly-less-useless crank pulley holder:
https://www.amazon.com/dp/B0B977W7S4
two washers, and this one is good. stupid though that Ford won't sell their kits through dealers, and there are so many crap toolkits that finding a decent one is so difficult.
