OEM-Ish Equipment... What are my options?
This. Always look at tire height in relation to the original height of 23.4". The 225/45R15 is only 23" in tire height so they are shorter than the OE size.
A good reference at this point is stay as close to OE tire height as you can but widen the tire as much as you can. The car needs as much grip as it possibly can get. Some approx. measurements from Tire Rack on sizes:
205/50R15 - 23.0"
225/45R15 - 23.0"
205/45R16 - 23.4"
215/45R16 - 23.6"
225/45R16 - 24.0"
205/50R16 - 23.9"
205/40R17 - 23.4"(OE SIZE)
215/40R17 - 23.9"
ah 205/45 16 is 23.26 not 23.4 its shorter than stock ride height.
Oh and your 215/40 17 is off as well its 23.77 not 23.9. I k ow this because I ran 215/40/17’s and like to look things up:ROFLMAO:
As for 16’s
I also know this because I ran 205/45 16 RS Pro’s before I put on 215/45 16 RT660’s. So you can either go 7% taller and gain higher ultimate grip or go 8% shorter and get slightly better turn in at the expense of less ultimate grip because you have a narrower section with and tread patch.
Now this can vary as well as most manufactures do not absolutely adhere to sidewall stated section widths. My RS pros had a section width closer to if not wider than some 215’s . It probably measure out between a 210 and a 215 but not a 205.
Now my RT660’s are the same way they say 215 on the sidewall but have a section width that’s actually as wide as some 225’s . Both Federal and Falken are known for running wider than stated section widths.
Thats why its always wise to look for the measured section width vs stated . Ya Tire Rack lists that.
Federal has it on their website. Other tires it all depends.
^^^There is some variance within the sizes as concerns the height/overall diameter as well as the width, albeit not as radically different.
I.E.; some 205/50-16s are 23.9" tall and some are 24.1" tall, some 215/40-17s are 23.7" (like you've stated), and some ARE 23.9" tall as well. [wink]
XanRules
XanRules
Portland
Thread Starter #25
A brief bump as I'll probably do this at some point this calendar year. I'm thinking a bit more about the advantages of a progressive rate spring, like the Mountunes, for a daily driver, but I am once again totally overloaded with information. My impression is that progressive rate springs are preferable in some ways for a daily driver, offering a more comfortable ride in most situations and a little more leeway in suspension travel if you're going to be, oh, hauling a bunch of guitars and speakers in your trunk.
Anyone who knows what they're talking about want to chime in? I am not on a time crunch so I've got time to learn before I pull the trigger on the B6s (or B8s? aaaauuuuugggghhh!!!) and Swifts.
Dave88LX
U.S. Air Force Veteran
York, PA
Yeah I really wish there was something definitive on the B6 versus B8.
Probably going to buy through Whoosh so I will just run whatever they tell me to.
CT
Recently put on B6 and swifts. Handling is really incredible, but as a daily on rough roads I'm debating putting the OE springs back on for both ride quality and low speed fun. Kinda miss some easier body roll.
I know I’m replying to an old post, but I know Ron of Whoosh says the Swift springs are designed to work with the B6. So based on that, I’d probably go with that combo if you’re using Swift springs.
THIS!
As when one contacts Swift's 'tech' department, even they are very 'wishy-washy' on which damper to use with their Spec R springs.
XanRules
XanRules
Portland
Thread Starter #31
Thanks for bumping this. I still haven't bothered changing out my suspension and was just thinking about this thread a few weeks ago. I work from home now so I do a lot less driving and the car still drives fine.
Ottawa, Ontario, Canada
I'm struggling with the decision as well. My driver side strut bearing is seizing up so need to do a refresh. At first I was just going to go full OEM replacement of the struts as I quite like the ride, but then started reading about potentially going with B6s, and that lead to reading about Swift springs, and so on. I have a 2014 so the ride is quite stiff, which I don't mind, but if I can get something slightly comfier without sacrificing too much body roll, that would be great.
Bay Area California
#33
If you are looking for ride quality, then you probably want a progressive spring instead of a linear spring like the Swifts.
PS: I have a V70R too.
Dialcaliper
San Francisco Bay Area
#34
Just a plug for off the shelf DIY spring setup that think turned out really well. Spring rates near the Swifts and stock ride height. Despite the stiffer springs, on rough roads the ride was slightly better than stock. I ran 225F/200R rates on B6 struts and it worked quite well until I went to my current custom Bilsteins.
Most of the poor ride quality on stock/lowered setups comes from the fact that you spend a lot of time deep into the upper range of the bumpstops, which even on a lowered Swift setup are nearly touching in front at stock ride height, and not far off in the rear.
The stiffer springs keep you out of the bumpstops more.
https://www.fiestastforum.com/threa...ce-springs-for-oem-b6-style-suspension.30829/
