Time Attack Fiesta Build
EscortSportage
U.S. Marine Veteran
NY
Recently bought a 16 ST building it into a fun street/track car. Full interior street class. Ive raced a fully built Coyote swapped foxbody for years. Parted and sold that last year, I wanted something fun, light, cheap that I can drive to the track.
NJMP Lightning Oct 2025 Shakedown
EscortSportage
EscortSportage
U.S. Marine Veteran
NY
Thread Starter #2
Mods:
Chassis
Swave front and rear strut/trunk braces
Swave 6 point tunnel chassis brace
Swave 4 point brace lower subframe
Swave 6 point chassis to subframe brace
DNA rear shock tower brace
Brakes
Motul 600 fluid
Stoptech rotors
Stoptech SS braided hoses
Hawk HP Plus pads
Engine
Whoosh hot and cold side charge pipes
Whoosh magnetic oil drain plug
Whoosh lightweight WP pulley
Velossa air scoop
Stock airbox
Afe dry mesh air filter
Whoosh silicon intake tube
Whoosh crossover pipe
Cobb Intercooler
Aluminum radiator
Transmission stuff
Whoosh shifter bushings both ends
Whoosh short throw shifter block
Boomba weighted shift knob
Safety
Sparco tow straps
Sparco driver seat
Suspension
TB torsion beam bar
SPC camber bolts
Powerflex rear beam race bushings
SEP rear axle beam centering kit
DNA rear camber plates
Wheels
16x7 Foxbody Pony wheels (Street)
16x8 RPF1 wheels (Track)
Ford SVT Contour wheels w/ snow tires
Flyin Miata lightweight lug nuts
Tires
Nangkang CRS
Aero
Ported rear valance (made the honey combs real)
Burlington, NC, USA
Put intercooler and radiator high on your list and some brake cooling via either the airtec or boomba diverters or a full on duct.
Grsemky
U.S. Navy Veteran
Arizona
I just got a set but didn’t realize how much you have to hack up the fog light bezel to fit it.
I couldn't remember if that was you or not, mostly I was throwing it out for OP
EscortSportage
EscortSportage
U.S. Marine Veteran
NY
I have a cobb intercooler and triple pass aluminum radiator in my living room waiting to go in, Im also doing the scoop in front of the airbox and the front tow strap all at once when i have the bumper cover off. Im going to build some brake ducts as well.
EscortSportage
EscortSportage
U.S. Marine Veteran
NY
Theres also that kit the deletes the foglights if you ever wanted to go that route.
Fusion Works
Huntsville, AL, USA
Sell the triple pass radiator and get a Koyo or Pro Alloy. Triple pass only increases the pressure in the system. It doesn't help with flow. Might be marginally cooler than stock, but definitely not as good as it could be.
EscortSportage
EscortSportage
U.S. Marine Veteran
NY
I know its been a while, slowly installing parts as they come in prepping for the track season which starts in April.
Whoosh RMM came in, Cobb AP came in, were moving along. (I need to post pics)
EscortSportage on Instagram if you have it.
hawyee
Active Duty U.S. Air Force
OKC
Not sure if I missed it but what suspension?
EscortSportage
EscortSportage
U.S. Marine Veteran
NY
stock for now, added the TB bar in the rear torsion arm. Plan is to add camber and maybe coilovers at some point.
EscortSportage
EscortSportage
U.S. Marine Veteran
NY
Alright CRS tires are on, Cobb intercooler installed, Big mouth scoop installed, and Eibach rear bar installed....
