LSD Installation Thread
Paramus, NJ, USA
Looks like I'm attempting to get my Wavetrac in the weekend of the 13th, borrowing a mechanic friend's shop space and experience. I've got the LSD install kit, RTS slave cylinder for while I'm in there, and I figure I probably should pick up most of what is on the now very old list Worthams provided, barring anything clutch/flywheel related. Anything I'm not thinking of or should be aware of? I appreciate that in the years I've owned this car and have read threads on LSDs, there's still no single conclusion on if it's actually worth buying shims or not.
Frankly I'd still rather just have it done with Clarke because I like smooth transmissions over chunky ones, but I'm not flush enough with cash to front $5600 without shipping and have my daily driver down too. So I have to learn instead of getting to be lazy.
It’s hit or miss with needing shims. Ive seen some not needing it, and as you can see with mine, I needed shims.
I’d say change the input shaft bearing. It practically fell out with a little heat on the transmission case.
Portland, OR, USA
Obviously the logical answer is to buy shims, but man, they do not make buying them easy or cheap lol. Especially given there's no way to know what you might need. Good call about the input shaft bearing, I'll look at picking one up
Paramus, NJ, USA
If you buy and don’t open, you can usually return them. Talk to your Ford parts department first.
Brookeville
Hi Sluggy, your blog is no longer available, did you happen to still have a copy that is accessible somewhere?
Hey howdy. The blog is there, but unfortunately it's hosted on a server that's old as dirt and doesn't have HTTPS so most modern browsers like to choke on it. I printed the page and uploaded all of the PDFs to a Google Drive - hopefully this will work!
https://drive.google.com/drive/folders/18DMcw5Q5LDDxWZZn1WYw9IB4WiAgXDu7?usp=sharing
manual is here: https://drive.google.com/file/d/1E_Kps6fj5X225LwxT67_AF_2GbPU80a5/view?usp=drive_link
Let me know.
Australia
Let me know.
Mate!!! this is pure gold. Thank you!
And the 3D printed files I had planned to draw up myself, you just saved me hours!
Thanks again
