Date: December 6, 2014
Mileage: 3,355
Mods:
- COBB Exhaust Hangers
- COBB Cat Back Exhaust
Decided to take advantage of the savings COBB was offering and pick up this exhaust. I really don't have enough good things to say about this piece. The materials, welds, fit, finish and overall quality are top notch! I'm a firm believer in "you get what you pay for" and that definitely holds true with this setup. I researched all of the other available options and I didn't want to go there with slip joints, bolt on tips, small diameter piping, inferior materials etc etc...
The install should've been super straight forward, but both the nuts on the DP studs were completely seized. We were able to get one of the nuts off, but the other one snapped. After a few headaches we removed both pressed in DP studs and used bolts. Oddly enough COBB included extra hardware to use from the DP to Catback connection. I don't know if this is a known issue, or if the extra hardware was there to be used with their DP. In any case, everything was very easy once the studs were out. Fitment is PERFECT!
The sounds this car makes are now incredible. On the 20 minute test drive I couldn't stop grinning. 2nd gear 3/4 throttle from low RPMs is a complete riot. The tone, snap, crackle and pop all add to the fun. ZERO drone, ZERO annoyingness, all around couldn't be happier. Literally the perfect exhaust for our cars IMO.
The hangers work great and eliminate the majority of the unwanted movement in the exhaust. The stockers are a complete joke and it shouldn't be a question of whether or not to upgrade them.
Pics:
 FiST COBB-5558
FiST COBB-5558 by
T_Forde, on Flickr
 FiST COBB-5559
FiST COBB-5559 by
T_Forde, on Flickr
 FiST COBB-2526
FiST COBB-2526 by
T_Forde, on Flickr
 FiST COBB-2528
FiST COBB-2528 by
T_Forde, on Flickr
