Gauging interest in a run of budget big brake kit brackets?
Are you interested in a set of brake brackets?
  • Hell Yes, I’ve got $400 burning a hole in my pocket
    Votes: 10 50.0%
  • Likely someday, but I’m not ready to put money down
    Votes: 8 40.0%
  • Nah, I’m fine with but this looks cool
    Votes: 2 10.0%
  • WTF?
    Votes: 0 0.0%
  • Total voters
    20
Dialcaliper
I recently completed a custom front brake kit using a set of 986 Boxster (non-S) calipers mated to 300x24mm bolt-on SVT Focus rotors.
I’m really quite happy with how they turned out, and in the process I ended up with a complete CAD design that I could, theoretically send out for quotes to local machine shops, if enough people would be interested in purchasing a set, which would mean getting at a minimum of 5 sets made to make the cost reasonable.
Fitment - They fit directly under my 16x8” Konig Dekagrams with no spacers required. The calipers stick out about 2-1/8” towards the spokes from where the factory FiST rotors sit, so you’d need about 2.25” of spoke clearance. (SVT rotors are at the same depth). I haven’t verified fit with any other wheels except my Autech 16x7” ET38 snow tires, which also fit. Some 15” wheels might also fit, but I’ve not verified any other wheel fitments. Unfortunately factory FiST wheels would not fit without spacers. There might be a different solution for that, but I haven’t had the time, money or motivation at this stage to develop that since they wouldn’t work for my setup.
It’s currently looking like I could probably get them made for between $375-400 per set. This is a bit more than you’ll see for some equivalent parts available online for other platforms, but I’m not getting the kind of volume discounts they are (or someone like Ron could get)
What the kit would include:
- 2x Brackets for adapting calipers to the Fiesta ST front hubs
- 4x Grade 12.9 Bolts for attaching the calipers to the brackets
What you would need to supply yourself:
- 1x pair of factory Brembo FRONT calipers from a base model Porsche 986/987 (2.5L or 2.7L) Boxster. Any year from 1996-2012 should work as long as they are the gray Non-S type. (The S calipers are usually red and are made for a thicker rotor and slightly different mounting) I found mine used on eBay for $300
- Optional, for under $100 you can get a rebuild kit for the calipers with fresh seals and boots.
- 2x 300x24mm rotors meant for a 2002-2004 Ford Focus SVT. These are a direct fit on the factory FiST hubs with no redrilling or messing around. Centric rotors are ~$40 ea on Rockauto, or a bit more from Tire Rack
- 4x Factory FiST caliper mounting bolts. You can probably reuse the stock bolts if they are in good shape.
All told, you could probably get all the extra bits for $500 with fresh seals, but not including your choice of brake pads, which of course you’d also need to buy separately.
Including brake pads the total price tag comes in right around $1000, comparable to budget kits like the Wilwoods, except in this case you’d get OEM quality Brembos, Porsche brake pad selections and availability (spec-Boxster) with generous pad area and inexpensive OEM rotors.
The brackets would be machined from 6061-T6 Aluminum, Hard Anodized for corrosion resistance and installed with Helicoil threaded inserts so you don’t have to deal with the downsides of threading steel bolts into relatively soft aluminum. At the moment I’ve redesigned them to reuse the stock caliper mounting bolts for ease of install instead of the ARP’s I used for my build, but could reconsider that if people would rather spend the extra coin on the ARP’s (an extra $60-70)
If you want to know all the dirty details of the development I did, there is a 5-part post in my build thread here:
https://www.fiestastforum.com/threads/feisty-the-family-car.30825/post-522405
I’m in for a set with all ARP hardware
Dialcaliper
Dialcaliper
Looking for anyone interested
I’ve been trying to avoid it hoping there’d be interest here, but threw a post in the Facebook group to reach wider audience
Ive already got the old Jaguar/Fusion kit, but i would be in to get this done, have the brakets, and then i could put the parts together later!
ronmcdon
that would be a great option if it would clear 16x8 +38 enkei rpf-1’s. the wheels are notorious for poor caliper clearance. My guess is the similarly sized Dekagrams would have a bit more caliper clearance.
I'd be in if they were to work with Stockers! But i know i can wish in one hand and poop in the other and see which one fills up first! [drummer]
Dialcaliper
Dialcaliper
As mentioned before, you’ll need about 2.25” out from your stock rotor to spokes (the caliper sticks roughly 2.125” from the rotor)
To do a run, I’ll have to pick one or the other, as the ARPs and OEM bolts have different thread pitch (different sized hole).
Count me in for a run of either, or both if they happen. Already had the calipers and rotors sitting around & this saves me from figuring out brackets. Trying to have a solution in place once I go through the 1.5 sets of Gloc R16s pads I still left have for the OEM setup. They will last me another 3-4 days, which should cover the rest of this year at the track at least.
Dialcaliper
Dialcaliper
Thread Starter #14
Okay, seems like there’s interest. Here’s the plan:
- All brackets are going to be with the ARP’s and I’ll include them in the kit. Resubmitted to the machine shop and just waiting back on them to send the requote.
- Final price with ARPs will be $450 - I was able to find a local machine shop that previously quoted only slightly more than getting parts made overseas through Xometry/Protolabs.
- However for those willing to put money up front to help move this along, I’ll discount to the original $375.
Once I kick off the order I expect it to take about 3-4 weeks to get the parts made and organize everything to get the brackets starting to ship out.
Pumped for this! Let us know when you’re ready for payment sir,
Dialcaliper
Dialcaliper
Thread Starter #17
Alright, I’ve gone ahead and kicked off the order with the machine shop since lead times were getting longer. With finishing it will probably be closer to 6 weeks, so I’ll probably be able to start shipping around Nov 10th.
We can work out details via PM. Anyone that would like to pre-pay between now and Oct 1st (before I need to start budgeting to pay off the credit card) will get the $375 price
Dialcaliper
Dialcaliper
Thread Starter #19
Wanted to give you guys an update. The order I have placed is for 10 sets. I’ve sent out invoices and requests for six of those and two more are likely also spoken for, so basically two sets are remaining up for grabs.
If you’d like in on a set, contact me as soon as possible. If all 10 are claimed and paid, I might be able to increase the order to 15 sets, but the machine shop needs to know by tomorrow (asking about Friday). After that it would likely be next year before I could do another run, assuming enough people are interested, but once the first 10 are sold, I’ll need to go ahead and set the price up to the $425 mentioned to make sure I don’t end up in a serious financial hole in the event not all of the additional 5 sell, as this has gone up to a personal outlay of several thousand dollars to get these made!
Dialcaliper
Dialcaliper
Thread Starter #20
Update on ordering:
I have paid invoices for 7 sets and interest expressed on 4 more. I will finalize the order qty with the machine shop by midday tomorrow if I can confirm up to 15 total sets (Friday). If I do, that leaves up to 4 more sets available at $375 and unfortunately I have to cut off adding more sets after tomorrow morning.
The following are the confirmed paid invoices:
- Dhminer x2
- Stubborn Approach x2
- Mbigham
- MrMann
- Ttercel
- EMS
- porambo
- (One person not on forum)
After I get all the orders in I’ll be working on a proper instruction set including the identifying part numbers and some links where possible so you can make sure you’re finding the right items and hopefully nobody goes and buys the wrong parts (so, no need to rush out and buy stuff if you’re not 100% sure). Also install instructions and torque specs will be included as well
