Lemon's X47 track ST
lemonjs
United Kingdom
Thread Starter #161
I attended a hill climb school yesterday at Gurston Down. The format was along the lines of:
1. Class room time discussing the track, hill climb as a sport in general, and information on their club
2. Track walk with an instructor that included commentary on the corners, breaking/accelerating points etc
3. Convoy runs with the instructor in the lead
4. Individual runs throughout the day with instructor feedback after every run (they each took a section of the track)
I wanted to see if hill climb was a potential starting point for motorsport for me instead of time attack or proper circuit racing as it would be considerable cheaper.
While I enjoyed the day and had great fun driving, the value is pretty terrible when you consider a run is 40-45 seconds and you need to wait for the other 25 cars to finish. The total seat time for the day was around 8 minutes, with the remainder of the day waiting around in the sun. The price is similar to a full track day where I'd get easily 1.5 hours of seat time, with the limitation being how much time I want to spend in the car.
Most of the day was hot and dry, but it rained for the last two runs.
A real mixture of cars:
It looks pretty slow on the video, but it was quite scary given how narrow it was!:
I'll probably take it easy for the next month and get the car prepped for the Nurburgring.
hawyee
Active Duty U.S. Air Force
OKC
That's similar to autocross in the US except for that you have to work the course as well when you aren't driving, so I think hill climb would be a better value for seat time. Where else do you get to full send on a public road as well? Also the competition aspect is really what makes it worthwhile, class wins can and often are decided by tenths or hundredths of seconds in those events. Hill climb is on my list as well of fun things to do with the bean eventually
^^^I forgot if your car has at least a certified roll bar in it or not, but most hillclimb sanctioning bodies here in the states (including the ones run under SCCA Solo 1 rules and regs) require at least that for the slower classes, and full wheel to wheel spec cages for the upper, faster classes.
lemonjs
United Kingdom
Thread Starter #165
Less than a month now until my pilgrimage to the Nurburgring! I have no more track days between now and then and won't be driving the car much, so I had it in the garage at the weekend to do some prep.
First item isn't prep, but made sense to do while the discs were out, new Pumaspeed adjustable drop links:
I did notice this crack a week or so ago but did not realise it went through the whole disc! There's also quite a few Js missing from my J-hooks!
At £380 for a set of front discs, they are not cheap, especially compared to stock discs. I did consider going back to the OEM set up with braided lines, but I absolutely love the performance from these brakes so will stomach the cost.
The old Motul RBF 660 was looking gross, but had been in there for around 18 months. The brake pedal still felt pretty good but was time for replacement. Fresh RBF 660 went in, just under 1 litre total.
I ended up refitting the existing EBC RP1 as they had around 60% left and had worn pretty flat. I will pick up a new set for the ring. I'm undecided if I prefer RP1 over RPX. The RPX is so confidence inspiring as the bite is vicious, but it's very hard to modulate. RP1 on the other hand feel just like normal pads, but do eventually feel like they have the same stopping power.
And finally oil and filter change using Castrol Edge 5w30 and a FoMoCo filter. The only extra thing I think I'll do before going is to stick down some rubber sound proofing material in the front to take the edge off - the drive is going to be horrific even with noise cancelling headphones. I'm not sure if we will pass through the Netherlands, but if we do it will be 5 countries in a single day!
lemonjs
United Kingdom
Thread Starter #167
Those are 330mm front discs (or more than that)?
How long is the ferry ride across the Channel?
Yep! 330mm. I do regret getting such large brakes as it means I have to run 17s. If I was to do it again I’d get 290mm and run 16s.
The ferry takes around 90 minutes, but we’re going to take the Eurotunnel which takes around 30 minutes.
warszaw
I run 15-inch wheels, and they are amazing with cheap semi-slick tires. I believe that 290mm brakes could fit under a 15-inch wheel.
lemonjs
United Kingdom
Thread Starter #169
Back home now after the craziest 4 days. Ended up driving over 1100 miles, drove 11 laps of the Nordschleife and a session on the GP track - the Fiesta didn't miss a beat the whole trip.
No amount of videos or sim time could prepare me for how absolutely insane the Nordschleife is. The speed, elevation and blind corners should not be legal! It took 6 or 7 laps before I wasn't terrified of going out there. I found the best thing to do was to lock in behind an experienced car and do a leader/follow style thing - most guys there seemed to know that was what was happening and kept on the racing line without trying to move over. I didn't manage to get a single lap in that didn't have a yellow flag, and there were around 10 serious crashes a day which often closed the track. Next year I'll definitely go back mid-week and/or do a track day.
Even crazier was meeting up with hawyee and spending the whole day at the ring with him. Top guy!
Doing 100+mph over a drop, getting four wheels off the ground and then immediately braking for a corner really gets the bum clenched:
The US and UK beens meeting in Germany, does this make Fiesta Forum history?:
I even met the main man Misha, sadly we couldn't get a lap in due to lap closures:
And finally on the train home. I'm very proud of the Fiesta, it took 4 days of abuse and didn't complain once:
Spring, TX
The Ring is top of my bucket list. Not likely in my own car, so it'll be interesting to see what rental options are available when I finally can get there. Cool you got to meet Misha, I enjoy his videos/channel.
rallytaff
Los Angeles
I can't believe that while I spent 7yrs in Germany, based in Verden, Dusseldorf and Moenchegladbach, that I never went to the Ring. I went to Spa with an officer who had a race car and I rallied in the Liege International Police Rally 5 times using a borrowed RAF Ford Escort, a rented Belgian Citroen Visa, my own Vauxhall Chevette HS2300 and Army Land Rovers. Oh well, my loss!
lemonjs
United Kingdom
Thread Starter #174
Next time I go I’ll definitely be visiting Spa on the way, it’s only an hour or so away from the ring. In hindsight driving the whole way in one go probably wasn’t ideal, I think stopping in Belgium overnight and doing a full day at Spa before heading to the ring would be much better. Also midweek TF sessions look so much quieter than weekend ones.
Here’s another photo, the bean is a tripod!
rallytaff
Los Angeles
I have posted elsewhere where I described doing a special stage in a Land Rover using half of the circuit!
lemonjs
United Kingdom
Thread Starter #176
Small update. After reflecting on my trip to the ring I've decided I want to visit several more times next year. I think I'll do a mixture of week day TF and track days, as well as a bunch of track days at home in the UK. I had seriously thought about getting a competition license and entering into time attack, but I can't imagine I will have anywhere near as much fun as I did at the ring.
With that in mind, I've started thinking about making the car a bit more of a 'ring tool' as the 8-12 hour drive was pretty miserable. I know I don't want a full OEM interior, and being completely stripped out was also too much but in the other direction. I've started by refitting a full dash, centre console and heater, so I will at the very least have an arm rest, cup holders, and somewhere to store stuff.
Next steps will be to fit some lightweight door cars, and potentially refit the carpet and some of the plastic trims. I have a track day on the 29th for me to get a feel for things. After driving the car at 1020kg I am worried about it feeling a bit fat and boaty by adding the weight back, so I will take it slow adding stuff back and weighing as I go.
lemonjs
United Kingdom
Thread Starter #178
How far is it to tow? I mean here we just hook the trailer to the truck and tow to the track with something comfortable to ride in.
We’re a lot more limited by space over here so it makes it quite difficult. I only have space for two cars, and my second car isn’t suitable for towing. I would need buy a truck and trailer and store them away from home which isn’t ideal, but is something I’m considering!
