Recently bought a 16 ST building it into a fun street/track car. Full interior street class. Ive raced a fully built Coyote swapped foxbody for years. Parted and sold that last year, I wanted something fun, light, cheap that I can drive to the track.
Chassis
Swave front and rear strut/trunk braces
Swave 6 point tunnel chassis brace
Swave 4 point brace lower subframe
Swave 6 point chassis to subframe brace
DNA rear shock tower brace
Brakes
Motul 600 fluid
Stoptech rotors
Stoptech SS braided hoses
Hawk HP Plus pads
Engine
Whoosh hot and cold side charge pipes
Whoosh magnetic oil drain plug
Whoosh lightweight WP pulley
Velossa air scoop
Stock airbox
Afe dry mesh air filter
Whoosh silicon intake tube
Whoosh crossover pipe
Cobb Intercooler
Aluminum radiator
Transmission stuff
Whoosh shifter bushings both ends
Whoosh short throw shifter block
Boomba weighted shift knob
I have a cobb intercooler and triple pass aluminum radiator in my living room waiting to go in, Im also doing the scoop in front of the airbox and the front tow strap all at once when i have the bumper cover off. Im going to build some brake ducts as well.
Sell the triple pass radiator and get a Koyo or Pro Alloy. Triple pass only increases the pressure in the system. It doesn't help with flow. Might be marginally cooler than stock, but definitely not as good as it could be.
