Cost to buy and install Koni SRT.T orange shocks...
hello.. sooo.. just venting here if you want to read it.... i dont usually have the time for my DD to be down so some of the work on my ST is not always done by me especially if it requires tools i dont have on hand. I *think* i want to get some Koni str.t orange struts/shocks for a nice ride that isnt so jarring, and the car has 70,000 miles on the OEM shocks. I can get the shocks struts for and other hardware for about $500. The local repair shops wont install customer supplied parts ( and i get that) but they quoted me $2400 for the koni STR.T shocks struts, mounting parts, and labor.... They said labor was $640 (not bad) but the up scalle on the parts? how much is that? its over 3 times! i asked the mechanic on the phone about it and he gave me a premade speech of how they need to uprate parts costs, and how my parts are junk because they came from the internet even though its still a Koni product from a reputable source! i WISH i could work outa my garage and charge $2400 per job for struts/shocks... id be rich.
Grsemky
I mean the struts only take a few hours to install, the rear being the easiest... I even purchased a spring compressor from harbor freight and then returned it the same day after I was finished! Accomplished with a single jack and two stands in a parking lot.
Sam4
shops always go list price no matter what they pay.
i just put b6's on mine. hand tools, 18mm, 15mm, 13mm, 10mm offset box wrench, and a pair of vice grips to hold the shock shaft while turning the top nut. Jack, 2 stands, and a borrowed spring compressor from autozone. The job is pretty straight forward. Rears are especially easy. just the 2 13mm at the top, and the 18mm at the bottom. Make sure you torque the lower bolt at ride height, not at droop. I got the shocks from tire rack and got a good price.
I'd find a different shop if you're going to have someone else do it. That's a lot for even Koni Yellows.
