eBay Radiator
California
Does anyone have an upgrade eBay radiator that actually fits well and uses the stock fan and the stock fan fits well? How is the temps in hot weather and does it run cooler than oem radiator?
Grsemky
Arizona
You'd trust a no-name radiator for less than $200? I went for the Mountune and got them to install.
I do, and did... Not that specific model but a generic clone none the less, no issues in 1.5 years in the desert. Though being a mechanic by trade I'm not worried about labor to replace and have been more than satisfied with my gamble...
R
California
Here you go, it looks to be out of stock but assuming you get a 3 row that looks like this one https://www.ebay.com/itm/266165037576 it'll likely be the same. I asked the seller if this was a 3 row or two row before ordering it.
Thank you, how much larger is it than oem? Does it hold more coolant?
Evo8
U.S. Marine Veteran
Charlotte
You're welcome. I didn’t measure the coolant, but it appeared slightly thicker, probably due to enhanced cooling capabilities. I didn’t measure the coolant drained from the factory cooler, and I flushed the vehicle three times with distilled water. I replaced mine as a precautionary measure since I drive long distances in the ST for work, and I try to avoid failures.
Grsemky
Arizona
I have the same radiator and its about 33% more capacity over stock... It's noticeably larger than factory and if you use a FL400 size filter line me, it's a squeeze but doable!
R
California
Thread Starter #14
Thank you!
