Has anyone tried the Costco synthetic oil?
pixelzombie
Chicago, IL, USA
I was just just reading up on it and the specs are certainly on par with the more expensive brands and the price is almost too good to pass up.
SFV, So.Cal.
I am not 100% certain, however I do believe that many of Costco's (brand) products are imported from China.
I will start using Costco oil when I start driving a Chinese car.
Pleasant Garden
Costco is a wonderful company. They test toilet paper like there is no tomorrow. I believe the batteries they sell under their name are Duracell batteries.
I have watched videos about the Amazon and Walmart oil they both tested fairly well. They are mid-tier products with a good additive package, so I'm sure the Costco oil is just fine.
I personally like Pennzoil Platinum I believe it is one of the best oils out there especially for the price.
gtx3076
US
I watched an oil comparison of Kirkland oil and a high performance name brand that was eerily similar. I'd go as far to day they were identical and he gave the oil high marks.
I plan on using it next oil change.
rallytaff
Los Angeles
Castrol Magnatec from Walmart. Around $28 for a gallon when I got it. Currently in the car now.
If you wanna go green, I recommend Molygen😉
:LOL:
IF I could know for certain that stuff used a mostly group 4 (PAO) and partial group 5 (POE) base stock, I would have kept using it.
But LM will not say, and no one else seems to know what they use, and claim it is just hydrocracked group 3 base stock with their Molygen additive.
Grsemky
Arizona
:LOL:
Yeah I don't get that far into oils, I like the tungsten additive and that it's UV reactive so I can trace leaks a little easier... Other than that I don't track my car though it's driven hard and it's changed every 3k... I could probably use a cheaper oil but oh well
That's why I really like my current oil (probably even over my second choice Amsoil Signature Series 5W-30), Ravenol DXG 5W-30.
It also uses tungsten in the additive package, along with a healthy dose of the trinuclear molybdenum, and uses a mostly group 4 PAO base stock with just enough group 5 POE/esters to help the additives stay soluble, and condition the internal seals in the engine.
Yes, it is even more $$$$ than the Molygen, but I can also leave it in the engine for 5K+ miles if I want to, even with short tripping and direct injection fuel washdown dilution.
You are smart and correct to change out the Molygen on that schedule, since it is marketed as a short drain, high performance, slightly lower starting TBN (Total Base Number) street/racing oil to compete against the Motul 8100 Power, which is in the same category, albeit with some claimed group 5 esters in the base stock mix (but who knows?)
