Has anyone tried the Costco synthetic oil?
pixelzombie
I was just just reading up on it and the specs are certainly on par with the more expensive brands and the price is almost too good to pass up.
I am not 100% certain, however I do believe that many of Costco's (brand) products are imported from China.
I will start using Costco oil when I start driving a Chinese car.
Costco is a wonderful company. They test toilet paper like there is no tomorrow. I believe the batteries they sell under their name are Duracell batteries.
I have watched videos about the Amazon and Walmart oil they both tested fairly well. They are mid-tier products with a good additive package, so I'm sure the Costco oil is just fine.
I personally like Pennzoil Platinum I believe it is one of the best oils out there especially for the price.
Quisp
Made by Warren oil from Dunn , NC .
pixelzombie
pixelzombie
It figures, I go to buy some and they don't have 5W-20.
gtx3076
I watched an oil comparison of Kirkland oil and a high performance name brand that was eerily similar. I'd go as far to day they were identical and he gave the oil high marks.
I plan on using it next oil change.
rallytaff
Castrol Magnatec from Walmart. Around $28 for a gallon when I got it. Currently in the car now.
If you wanna go green, I recommend Molygen😉
:LOL:
IF I could know for certain that stuff used a mostly group 4 (PAO) and partial group 5 (POE) base stock, I would have kept using it.
But LM will not say, and no one else seems to know what they use, and claim it is just hydrocracked group 3 base stock with their Molygen additive.
Grsemky
:LOL:
Yeah I don't get that far into oils, I like the tungsten additive and that it's UV reactive so I can trace leaks a little easier... Other than that I don't track my car though it's driven hard and it's changed every 3k... I could probably use a cheaper oil but oh well
That's why I really like my current oil (probably even over my second choice Amsoil Signature Series 5W-30), Ravenol DXG 5W-30.
It also uses tungsten in the additive package, along with a healthy dose of the trinuclear molybdenum, and uses a mostly group 4 PAO base stock with just enough group 5 POE/esters to help the additives stay soluble, and condition the internal seals in the engine.
Yes, it is even more $$$$ than the Molygen, but I can also leave it in the engine for 5K+ miles if I want to, even with short tripping and direct injection fuel washdown dilution.
You are smart and correct to change out the Molygen on that schedule, since it is marketed as a short drain, high performance, slightly lower starting TBN (Total Base Number) street/racing oil to compete against the Motul 8100 Power, which is in the same category, albeit with some claimed group 5 esters in the base stock mix (but who knows?)
