2016 FiST - ECT Wiring Troubleshooting (P1299)
Columbia, TN
SIT-REP:
I upgraded my Motor Mounts to Vibra-Technics and when everything came back together I had a P1299 code. The temperature gauge on the dash goes to max before ever starting the car, so the cooling system is functioning as it should. My working theory is that I bumped the sensor and damaged the wiring to the sensor during install/reinstall of the battery box. I am in need of the PCM pinout so that I can test continuity on the harness from the PCM to the sensor. I looked through the service manual at the link below, but was unable to locate a pinout for the PCM, only instructions to remove the PCM. Any help with trying to troubleshoot this harness would be appreciated.
https://www.fofiesta7.com/ford_fiesta_2014_2019_service_manual-1.html
TROUBLESHOOTING:
Re-seat sensor and wiring harness (Done multiple times at this point)
Sensor has been replaced with OEM DY1194
Used the cold water/hot water sensor in cup method to check the impedance on old sensor and it appeared to pass the test
I also tested the impedance on the new sensor while it was in the car and it giving similar readings
NEXT STEP:
Test continuity from PCM to Sensor *NEEDS PCM PINOUT*
Order new pigtail for sensor from Ford.
STRANGE FINDING:
This is what I found when I took the sensor apart. It's orange in color when absorbed in a paper towel, but doesn't smell like antifreeze. Even if it was antifreeze I have no idea how it would get on the plug side of the sensor. My thought is I have seen similar type oils on new parts. Could this be some kind of a protective coating of sorts to prevent corrosion applied at the factory?
F
Columbia, TN
Replacing the HCT Sensor and clearing the code resolved the issue. Clearing the code may have worked yesterday, but both sensors had at least some corrosion on them. I still need to delete the permanent code, but the CEL is OFF, temp is normal, and it is out of Limp Mode.
P.S. I would still like the pin-out for the PCM if anyone has it.
Saint Pauly
I got my Money on the Sensor failed internally and let coolant through and into the body side connector. Get some CRC Electromotive cleaner to clean out the connector. Replace sensor Also and clear the code.
F
Columbia, TN
I was surprised that the gauge was still showing hot until I cleared the code. To your point I think it makes a lot of sense too that the sensor failed internally as you mentioned, but the stuff didn't taste or smell like antifreeze, but sure the heck looked like it so IDK lol.
