- Member ID
- #5968
- Messages
- 55
- Likes
- 38
Delete / Lock
Hi all,
I was wondering how you guys are wiring your WMI fail safes. Is there a way to wire the fail-safe to your wastegate solenoid so if it triggers it would cause you to run waste gate pressure.
There was a post on an evo forum wayyy back when that mentioned they connected the ground wire of the fail safe to the ground of their wastegate solenoid. cause it had constnat power and a ground would trigger and create a connection. Not sure if this could be done with the FiST.
pictures, tips, guidance are much appreciated
Hi all,
