Weird Stop ![Really Confused [???:)] [???:)]](/images/smilies/confused.gif)
I was accelerating quickly in 3d around a rh turn to 5800, then slowed in traffic and upshifted to 4th. All good so far for a half-mile. Then slowed and stopped for a lh turn onto an onramp. After waiting at idle for 10 seconds the car just shut off (all systems) and the horn beeped twice. I started up, worked fine, and accelerated onto the highway. After a quarter mile the wrench light came on (solid not flashing) and the car seemed to go into limp mode. The screen went into "sync update in progress" and then went black, and my AP3 lost all connection to the ecu. I took the next exit and was coasting as the car had no power. Pulled off to the side and shut it off. Waited a minute, hit the start button, and everything works fine.
The car never overheated, gauges (boost, afr, oil and coolant temps, charge temp, and ign correction cyl 1) were fine before and after and boost is normal (no leaks). No codes to clear.![Clap [clap] [clap]](/images/smilies/icon_smile_clap.gif)
The car is stage 3 - 19,000 m with no prior problems except as below.
The other day I held the esc button in and it malfunctioned until I turned off and restarted the car. I also had the dead sound issue which I fixed by disconnecting the battery for >10 seconds as advised by Ford. And it was beeping twice when I started up a couple of times, but that stopped after a day.
So it seems to be a weird electrical bug and I wonder if anyone else has had similar experiences.
Thanks for any help!
