AWD Twin Engine Fiesta
Saint Pauly
#61
It’s been a while since posting here but I’ve gathered most of what I need into my garage. Getting serious now about starting as I’ve been gaining confidence in a new daily driver.
As next steps go…. I guess I still need a new trans.
I could wire it up and try and start it, or I could trim it more. I’m leaning towards the grinder.
Guy Fiery is thinking so in the back![drummer]
PapaJim13
Kalamazoo, MI
Thread Starter #62
This “220k” mile motor looks darn clean. Haven’t looked until now. With good oil change intervals can the head look that good with that kind of mileage? IMG_4537.jpeg
Since it's not an ST/turbo, yes it probably can remain clean like that.
On a 3-5k interval some naturally aspirated engines can remain very clean. Had a 1.9L SOHC SEFI 88HP engine that was like that for quite awhile.
PapaJim13
Kalamazoo, MI
Thread Starter #65
Slow progress is still progress. I want to be able to run the motor out of the car so I built a test stand. I still have to figure out a trans mount so it sits right, but it’s together enough to move around the garage.
PapaJim13
Kalamazoo, MI
Thread Starter #66
The garage is quite the mess right now working on this among a bunch of other stuff.
I connected the engine wiring harness to the engine and the body harness to what's left of the body. Took me a min to untangle the spaghetti and lo and behold, nothing happens when I connect the battery. I figure the screen would at least light up with the battery "connected" (using jumper cables). I'm thinking it's a ground issue as the car doesn't exist anymore. I also didn't have the key on me, but I didn't see the theft light flash on the cluster either. I couldn't get a change in outcome regardless of where I moved/connected my negative jumper cable.
Does anyone know what the necessary grounds are to run the motor out of the car?
Is there a good resource to find those cool 3d wiring pics so I can chase wires? It's hard to tell what's what with no frame of reference.
If the car has PATS (Passive Anti-Theft Security) getting it to run may be quite difficult because all the little modules need to communicate in order to authorize function. Even if they're communicating, stored/active codes can prevent operation. The 2014 manual linked somewhere on the forums will be for the ST version of the vehicle.
PapaJim13
Kalamazoo, MI
Thread Starter #68
I think it’s exactly the same, if not very similar to the st. It’s a push to start model. I had the keyless entry module disconnected though. Even with that, I’d expect to see at least the theft light flash.
Wasn't aware that the ST has a security light. Having the roof liner out, removes an antenna, which sets a code in the BCM, which then leads to a host of other limitations...
https://www.fiestastforum.com/threads/headliner-removed-interesting-side-effects.23500/
Had to hold the "key" up to the RFID sensor in the steering column when pressing the button in order to activate the ignition and crank/start the engine.
PapaJim13
Kalamazoo, MI
Thread Starter #70
I may have shot myself in the foot when cutting the car apart. I cut that headliner connection out of the wiring harness as I thought it wasn’t needed (stupid) and also threw away the center console and attached wiring for the key antenna. If those parts were specific to my key I’m thinking I’m SOL.
It’s probably easier to go standalone in my case anyway. I’ll start reaching out to companies about it. Any recommendations?
I'd assume any antenna of the same part number to work without reprogramming the BCM. Anyway the one in the steering column should be the only one you'd require for now. Reading the codes in the BCM will let you know what to go after.
PapaJim13
Kalamazoo, MI
Thread Starter #72
We have lights! Quite the light bulb moment when I measured 10 volts between the dash metal and ground. I loosely connected all other grounds I saw with twisted wires and alligator clips and saw the key not found message displayed. I hit unlock while holding both fobs right next to the sensor and the message went away. Thing beeps and beeps at me almost like it knows its in pieces lol. I tried to start and the beeping went away like it was trying to start, but the starter didn't engage. That's okay for tonight though.
PapaJim13
Kalamazoo, MI
Thread Starter #73
I got it running on starter fluid today!
I’ll need to improve my jumper cable grounds to something more permanent as the starter had trouble pulling enough current.
Next is getting my fuel pump attached to a 5 gal bucket lid and getting it to run on its own fuel. I’ll upload a video of me redlining the shit out of it when I do.
PapaJim13
Kalamazoo, MI
Thread Starter #74
Well…. I got it running on its own fuel today. Used the stock fuel tank with O’Reilly fittings, fuel line, and inline filter. Bought 2 fire extinguishers for the garage for extra safety.
And as promised I gave er some revs.
https://youtube.com/shorts/PpOMYCclFcw?si=hPvIukW0mZghtjNQ
