Boost Leak Problems
Grsemky
U.S. Navy Veteran
Arizona
#41
I will if I end up swapping it. My mechanically inclined friend is pushing me to change out the compressor housing seal before diving into a turbo swap. I’m game to try given I’ve got some transmission work that’s already going to hurt my wallet (clutch, slave, axle seals)
I would give it a shot, I see rebuild kits for KP39 turbos on eBay for like $30
Houston, TX, USA
#42
Well this is not confidence inspiring... found this thread the other week while trying to troubleshoot a "low boost" issue with my car, and just checked back to see if you figured anything out. I plugged my AP in recently to monitor coolant temps after replacing my expansion tank, and noticed I was only seeing ~22 PSI peak (Stratified flash tune). I never bothered data logging 6 years ago when I loaded the tune, and don't recall exactly how it ran, but I assume I was seeing 24-26 PSI as one would expect for that tune. Now, boost peaks at 22.6 PSI around 3800 RPM and tapers off to 13ish at redline. WGDC is 84-86% the entire time, and ETC angle flat lines at 81-82% from around 3000 RPM onward. Threw the log file into vdyno and it came out at 174whp @ 4300 / 219lbft @ 3600. Definitely not right.
Crawled under the car today while changing my trans fluid and didn't notice any signs of oil leakage around the turbo, so maybe not the same issue you found. I guess I'll buy a DV+ and go from there.
Burlington, NC, USA
#43
Glad you found the issue! Rebuilding the turbo is a good idea however if your financial situation allows it comfortably, you won’t regret a turbo upgrade.
S
San Diego
Thread Starter #44
Believe me I would like to, but it’s hard to justify a $2k turbo upgrade with tuning etc. when a seal kit is $30. But we will see, once the seal doesn’t fix it I’ll just pick up a new turbo :)
S
San Diego
Thread Starter #45
What happens when you swap out the tune for a Cobb Stage 2 tune? If you make up to max boost on their tune it likely is a leak, but if it stays a few PSI Short you may have something similar to what I have.
