The car builds boost but doesn’t seem to do so as fast as it used to, nor as powerful... seems laggy. Access port fake torque estimate is only like 205 lb-ft. Never used that reading before so I’m not sure if it means anything. Still, stock turbo and bolt on upgraded pipes, IC and Tune+ tune should and was a lot peppier prior.
Regarding the bypass valve, I totally disassembled the DV+, cleaned and re-oiled the piston. The finish was a little worn on the top of the piston, but otherwise looked fine. Turbo smart plumb back bypass valve with the electric solenoid was no better (little cooler sound) and a hell of a bear harder to get installed because of the shape of it (that screw on the right was hours of work trying to get in place).
Sorry, fat fingering names of stuff. Brisk plugs yes, and Castrol Edge... car has been full synthetic Castrol Edge or Penszoil full synthetic equivalent and Fl-400 filter since the first oil change at 1500 miles.
I guess I just need to triple check the vac lines. I hope my turbo Wastegate or worse isn’t messed up somehow. I’m not hard on the car and it’s well maintained with pretty mild mods.
