Finally after 2 days of having the car on jack stands and soaking this last dang bolt holiding the OEM downpipe to turbo I finally took it off tonight and removed the stock downpipe. Now I ordered my ATP downpipe from stratified to also get that $50 tune credit. What I received was the box, bubble wrap, and the catless downpipe with a baggie of hardware taped to it. No instructions. I dont need instructions on the install but what about the hardware? I wanted clarification on what to do before installing the ATP. I will be buying a new gasket tomorrow and installing after work. Hopefully someeone has pitched in by then.
P.S I snapped one of the 2 15mm bolts that hook up the downpipe to catback. Do I need to get another on or is that what the 2 double sided slightly wider threaded black pieces are for?
Thanks just havent seen much for ATP.
Disposing off the header and downpipe heat shield as it was nearly imposing to take out so not going through that again to reinstall.
