Clunky shifting into 1st and second, and whine in 6th around 65 mph
Santa Rosa
currently at around 300 miles on car but has been doing this since around 100 miles. i should probably take it in to see whats going on. i don't think its my driving!
me32
fairfield
What do you mean by clunk? Are you sure at 65mph in 6th gear its not tire/road noise?
Chris G
San Diego
Clunk in 1-2 is probably the dual mass flywheel. My transmission also has a faint whine in gears 5-6 while cruising. It's been that way since day 1 and I'm at 22.5k miles strong.
Daphne
Sounds about right. The Fiesta is by no means a refined car. It makes many different mechanical and strange sounds all the time. I gave up listening for out of place noises on this thing. If it still drives it must be okay.
Sent from my SM-N920V using Tapatalk
S
Santa Rosa
As soon as i apply slight ammount of pressure to gas pedal around 65 its a higher pitched whine. The clunky shifting is the worst going into second. Just not a smooth transition and you can hear it. Hard to explain
Daphne
Second gear is pretty tricky to get smooth at first. I find that if you shift at anything more than 2k rpm, you need to start applying throttle as soon as you start releasing the clutch. It's kind of a balancing act. You'll get it down after awhile.
My ST has the same faint whine in pretty much every gear. As does a friends. It's more pronounced in 4-6, but never super loud or anything. It's kind of hard to convey what would be a normal volume is over the internet, though.
Saint Pauly
Pilot bearing? Turbo? Pretty sure mine has the same thing...it's not a bugatti so I'll get it in if I get time and it still drives down the road fine.
Santa Fe
I just had my trans replaced for exactly what you're describing. Started at 700 miles on a 2016. Ford originally approved a new output shaft bearing, but upon disassembly there was metal in the trans so they approved a replacement. This one shifts perfectly and I get no whine at 65mph/partial throttle, only the normal gear noise in 5th and 6th. Bring it to your dealer, the whine only gets louder and more annoying.
