Cranks but no start
Nikke21
Soledad ca
Hi guys, my first post. So I swap an engine on my 2019 fiesta st it had broken rings and cylinder wall cracks. On piston number 2. The other engine was from a 2014 fiesta st or a 1.6 turbo vin x.
I am having trouble getting the car to start and run normal. So it cranks and wants to start I do a combination of holding the clutch and giving it some gas to make it run. But it's shakes bad and 2 engine codes pop up p0365 and p0369. I swap them from the old engine, basically I have 4, 2 from old and 2 from new engine. All are same parts and still runs rough when I get it to start. It doesn't let me rev the engine when I step on the gas but funny thing is when I hold the clutch I am able to rev the engine at a higher rpm.
- I tested the battery it's good and full of charge.
-camshaft sensors swap
- crank sensor swap
Wiring for the cam sensor matches the one on A side. There is another code but was there from ild engine something about turbo purge idk I can get the code tomorrow
Any help or suggestions ?
