Datalog virtual dyno results
Here are my datalog dyno runs. This is on a custom mountune tune by Randy Robles that started as a standard stage 2 (FMIC) to a slightly modified version for my catless downpipe. This is the first revision for the downpipe so it should continue to improve. And no I don't count this as a real dyno it's just for fun.
rodmoe
Cool I could never get my data logs to map out that nice ..
Good numbers btw
Ghostwhite
The way I get the runs to come out clean is I have to watch exactly when it starts data logging then WOT then stop the datalog as soon as I get off throttle
I would sure like to get mine but I don't want another ticket.
Dave
What numbers did you use for the car parameters? I would love to compare the 3rd gear run I just did, thanks!
Ghostwhite
I actually didn't change too much from the focus st expect for the gearing, weight and final drive ratio. For more accurate results change the tire diameter to 23.4 and for weight 2740+ your body weight. I need to change my tire diameter and weight.
Ok thanks, with those numbers in 3rd from 4200-6200 (all I could manage) on the new V103 stock I am at
175 hp @ 5612
185 lb-ft at 4324
a weird 2nd gear run 3800 - 6300 (this was easier to pull off for obvious reasons, think it was a decline)
210 hp @ 4481
249 lb-ft @ 4481
Ghostwhite
Nice, I try to find the flattest road and do runs in both directions on the same section, then I have a good average between them that's about 10hp+- difference from the different directions
Yeah this was a quick run out at lunch with the new tune, I will get something good soon.
rodmoe
Playing around with some of my latest pulls getting way to hectic on the top end to do on street so may get it dyno's after the 4th of July depending on the shops openings..
The two runs on June 12 were one into the wind and one with a tail wind blowing about 15-20 mph same road in all
rodmoe
I Know thats why I suspect my data may be whacked.. will see in time Oh these are ALL Randy from Mountune Tune's as we progressed
Ghostwhite
Thread Starter #14
Yeah I was thinking maybe the wind was part of that flatness
MOFiST
I've downloaded Virtual Dyno. Our Fiesta isn't on the drop down list of the "CarEditor" for easy setup.
Can someone please list what numbers they used to fill the Properties and Transmission Info.
I'm on stock tyres and wheels.
MOFiST
So i was able to scrounge together the info using our favorite NSA search engine.
Here's what I came up with. Do you guys agree?
The weight is for the 3 door.
razorlab
2564 lbs.... ugh I wish our USDM cars where that light! Mine is almost 200lbs more... :-/
Ghostwhite
Thread Starter #19
I believe drag co. Is .32
Sourskittle
Is the software free? Where can I download it at? You just feed it a cobb datalog ?
