I have used these electrical connecters for over 10 years. Used as original equipment on Caterpillar earthmoving and mining equipment they are a high end connection suitable for extreme heat and resistant to a high degree of moisture. I always try to use Deutsch connections when ever I add a electrical component to OEM system. The only time I has seen a corrosion or continuity problem is when the connector has been damaged and that has been in a harsh mining environment too. The down side is the cost and the special crimping pliers that must be used.
Here is a few images I took today when I moved my E-Boost that I thought I would share.
Wirer strippers, these make life easier.
