DHM Aux Fuel System! Good up to 550hp!!
Trader history for DHM (0)
LT Berzerker
I've been running autocross and that's why I didn't want to go big turbo. The LSD made a big difference but the torque vectoring nannies caused some extra brake wear; recently solved by buying the Fiesta B-SPEC ABS module. I brake late, yank wheel, keep throttle planted, holy crap what a difference! Just need bigger front brakes though...
How was the bspec abs install??? Any plan to do a diy/how to on the forum???
It really was easy just real messy.. brake fluid all over, have a lot of rags handy.. use flare nut wrenches so you don't round the edges of the brake fittings..
LT Berzerker
Thought I saw somewhere that the module didn't have the same number of inputs as we had lines in our car... Could be completely wrong though lol
rodmoe
My car was built to run HPDE at Road America and for that it was near perfect i did some parking lot stuff but the large turbo was not a friend there and we also found out a few other things the ECU will not let us do so back for a refit and see how this pans out. am looking forward to getting a few things done to the car for better low end power and less weight via a super light one off exhaust.
How did you get the B-Spec module to plug in as I had heard the plug and pin out from the ones they sell for the NA fiesta are different..
#29
Russ, I see Stratified has gone live with the aux fuel kit! The pre-ordered ones going out soon?
#30
I want to get the word out as i will be working on this very soon. Parts on the way and testing will be right around the corner! This will be a throttle body Aux injector set up. This will be a pretty straight forward plug and play system.
This tread will hopefully allow me to gauge the interest in this product as well.
Russ
Stratified is selling the kits already, what's up with our preordered ones?
DHM1
DHM1
Thread Starter #31
They are simply taking orders for the next batch.
Russ
#32
Russ
Dammit! Those teasing bas-turds! Ha! Ok.. with you being at 425whp have you thought about the Piper Cams and porting/polishing the head and going for 500whp?!
DHM1
DHM1
Thread Starter #33
Wish it was that easy. Stock rods and pistons are tapped out at 400-420whp. Also i dont think much over 450whp that the single injector is even enough cylinder to cylinder balance. But we will see!
Russ
#34
I haven't seen a straightforward answer, will we be able to run full e85 with this?
rodmoe
#36
yes but have not been tested yet.
This will be added and tested later this year on my car. after Drag race season is done and RUss gets to work redoing my BT to a Smaller BT kit for less lag and more torques at lower RPM on E85.. He has the car now just need time..
#37
You car is at the shop right now?!? I am so going to the shop on the weekend and checking it out! Smaller big turbo kit on E85. HOLY SHIT!! Ha, to exciting. I have to go see russ anyway to see about getting an intercooler and my E30 tune revised to the max.
rodmoe
#38
Yes it is there now and for as long as it takes to get it dialed in so he can offer a well rounded off the shelf (needing only minor teaks for your local) kit. By all means stop by and check it out..
#39
AMAZING NEWS!!! You my friend are awesome, Thank you. Trust me, I will be texting him this weekend and running up there. Looking forward to this to be done!
#40
I'm waiting on my aux fueling kit to run E85 in hopes that the cyborg I have can be pushed to a 350wtq around 3500-4000ish rpms with 300wtq from 2500 to 5000rpms... the short SCCA solo's and the Arroyo Seco Raceway near me is what I run... need low end torque!
