DIY Front Seat Cover Removal Help Needed
The foam padding, I assume, has shifted on the door side of my driver's seat base. I need to remove the cover and reposition the padding to prevent the metal frame from damaging the seat cover. Has anyone removed the cover. If so, any tips to doing so? Thanks.
I'm pretty sure after you unbolt the seat from the bracket you can see on the underside that there are clips I think. I need to replace my seat cover and I remember unbolting it and checking. Pretty sure it's just unbolt and then pop the clips off and then back on when you are finished.
Yeah, it just has clips around the perimeter of the seat base, they can be a bit of pain, a flat head screwdriver can help
