Door lock
Mpumalanga
Hi Enthusiasts. In south Africa we have a lot of break in's with the fords. Is the a better lock barrel that you know off. Also does the doors open from the inside if locked and the battery dies. My older car has electric with mechanical locking.
Rocketst
Chesapeake, VA, USA
Not sure which model y'all get down in South Africa but usspec back hatch won't open if no battery and they don't have a safety escape either which was stupid
Rocketst
Chesapeake, VA, USA
Otherwise if you unlock the doors prior to pulling the battery that solves 4/5 of the doors. The back 2 doors in my car won't unlock from the inside with no power but the fronts do even when battery is pulled.
ShaunPanday
Mpumalanga
That's a bit of good news on the front doors. Reason I'm worried is I know of an accident where the guy was trapped in the car cause the doors could not unlock
SFV, So.Cal.
If you have the fear of getting locked in your car then a tool like this should be carried.
Automatic Center Punch
Just use on any side or rear glass.
It will not work on the windshield.
ShaunPanday
Mpumalanga
Cool man. Was thinking of something like that. There are also glass breaker key chains
