I had posted to a previous weight thread, But I think it was more specific to weight savings for track since it was in the wheels & tires section.
If you have the weight of a specific part, post it or pm me with it and I will add it to the list. Since I couldn't find a general weights list, Hopefully this helps a lot of people find the weight info they are searching for.
FIESTA ST WEIGHTS:
OEM 1.6 Ecoboost Engine (DRY): 251lbs
OEM Crash Bar: 19.2lbs
OEM Downpipe: 8.16lbs
OEM Differential (including bolts, bearings, races) No ring gear: 9lb 8oz
OEM Motor Mount Passenger: 2.12lbs
OEM Transmission Mount: 2.15lbs
OEM A/C compressor: 13.4 lbs
OEM A/C Lines: TBD
OEM Condensor: 4.7 lbs
OEM A/C drier: 1.2lbs
OEM Radiator: 8 lbs
A/C delete bracket with pulley: 0.7 lbs
OEM 17x7 ST Wheel: 23.2lbs
OEM Bridgestone Potenza: 20.2lbs
OEM Full Size Spare Wheel/Tire: 36.4lbs
OEM (Non-ST Fiesta) 8 Spoke 15x4 Aluminum Spare Wheel/Tire: 19.2lbs
OEM Jack: 5.9lbs
OEM Battery: 26.4lbs
OEM Intercooler: 4.1lbs
OEM Intercooler Piping: 3.1lbs
OEM Hood: 25.2lbs
OEM Fender: 3.1lbs
OEM Bare hatch (Hatch & Glass only): 33.4lbs
OEM Rear Wiper assembly: 2.18lbs
OEM Wing: 5.84lbs
OEM front rotor and caliper 26.8lbs
OEM Steering wheel airbag: 2.5lbs
OEM Center console: 9.3lbs
OEM Strut Mass Damper: 1.2lbs
OEM Sunroof Glass/Motor/Tracks: 21lbs
OEM Front Caliper: 9lbs 2oz
OEM Rear Caliper: 5lbs 9oz
OEM Water Pump Pulley: 1lb 0.5oz
Driver Seat NON Recaro: 42.8lbs
Passenger Seat NON Recaro: 40.6lbs
Heated Recaro seat: 49.7 lbs each
Rear Seat Back 2/3 (w/bracket): 32lbs 9oz
Rear Seat Back 1/3 (w/bracket): 17lbs 10oz
Rear Seat bench pad: 8lbs 15oz
FIESTA ST AFTERMARKET WEIGHTS:
Batteries:
Antigravity ATX-20 Battery: 3.1lbs
Bumpers/Bracing:
TB Performance Crash Bar (Bare w/no tow): 13.6lbs
Mounts:
Vibra-Technics Passenger Motor Mount (Fast Road): 3.13lbs
Vibra-Technics Trans Mount (Fast Road): 3.8lbs
Brakes:
Wilwood front BBK caliper and rotor: 15.8lbs
WaveSpec Front Rotor: 13.5lb
Wheels:
16x7 Rota Slipstream: 14.12lbs
16x7 Enkei RPF-1: 13.6lbs
16x8 Konig Dekagram: 14.54lbs
16x8 Enkei RPF-1: 14.8 lbs
17x7.5 Team Dynamics Imola: 21.5lbs
17x8 Rota Grid: 18.9lbs
Tires:
205/45/16 re71-r: 19.5 lbs
205/50/16 Firestone Indy 500: 21lbs
205/50/16 Toyo R888R: 22 lbs
205/45/17 Potenza S001: 18.8lbs
215/40/17 Federal 595: 20.12lbs
Suspension:
Bilstein B6 Strut: 8.4lbs
ISC front coilover with Triple S spring upgrade: 11.7 lbs
Seats:
Planted driver passenger seat bracket: 8.1lbs
Planted passenger seat bracket: 7.1lbs
Sickspeed Suzuka racing bucket: 15.1lbs
Sickspeed Suzuka racing bucket mounts: 3.3lbs
Sickspeed Suzuka racing bucket sliders: 6.6lbs
Intake/Intercooler
Mishimoto intercooler: 11.2lbs
Cooling:
Mishimoto radiator - 12.12lbs
Engine:
Pumaspeed Uprated Lightweight Water Pump Pulley: 8.7oz
Exhaust:
MAPerformance Catback:
- front section: (missing weight)
- center section (s-bend): 3.1lbs
- rear section: 14.6lbs
- hardware: 3lbs
Exterior:
- SEIBON Hood Carbon Fiber RS-Style (WITH LINER): 15.14lbs
- SEIBON Hatch Carbon Fiber (Hatch and Glass only): 20.1lbs
FIESTA ST WEIGHTS:
OEM A/C Lines: TBD
OEM Radiator: 8 lbs
OEM Jack: 5.9lbs
OEM Hood: 25.2lbs
OEM Fender: 3.1lbs
OEM Wing: 5.84lbs
Batteries:
Bumpers/Bracing:
Mounts:
Brakes:
Wheels:
Tires:
Suspension:
Seats:
Intake/Intercooler
Cooling:
Engine:
Exhaust:
- hardware: 3lbs
Exterior:
![Wink [wink] [wink]](/images/smilies/wink.gif)
