Foglamp question
Clint Beastwood
Laguna beach
#81
So yeah, that's why I went with those iJDMTOY since there were so reasonable at only $73, and now I know I need to swap their orientation to get the clean projector cutoff I want... my experiments with the stock housings using Lamin-X and a few different H11 bulbs was just not good... And as far as headlights, going to carefully selected LED bulb with a proper chip design to mimic the halogen light point length is totally fine without causing excess glare, after a bunch have been tried, the TechMax Mini are inexpensive but perfect for our housing. I rocked that for a bit, and they totally provide better visibility without glare to bring attention from authorities so I recommend them wholeheartedly in your case... but, then I said, "You know what? I have a modern sporty little car, and I just really want projectors and the LED brow DRL..." so I went with those Depo Euro replicas and 9 months later, they have been perfect!
nice - no fogging or moisture buildup?
danbfree
Tigard, Oregon, USA
#82
With the Depo? No, they are replica's of the OEM and OEM is not designed to be air tight to begin with... I even don't even use rear rubber caps on the low beams since I use Katana H7 Bulbs and they have bulky cabling with an external driver. I even live in a rainy area and have no issues.
Huffman, TX, USA
#85
Is there a difference in OEM foglights between years? I have a 2019 and they don't seem that bad...I was thinking maybe earlier years got extra dim/crappy ones, or maybe my standards are low. :unsure:
slopoke
Livermore
#86
They are all the same. When I did mine, I went to a foglight/driving light combo, worked great for me. It was on the pricey side, but you have to pay for quality.
Sioux Falls, SD, USA
#87
I'm Rebuilding a front collision ST is there any point in buying Factory fog lights? Seems I could just spend a bit more and get High Quality LED's
