fogs
im going to do this within the next couple days, ill try to get some pics of the tabs that hold them in place
razorlab
I am currently using Nokya "Hyper Yellow" H11 bulbs for my fogs. They work great.
I also used the same brand and type in both my Evos and my Lancer Ralliart. In my Evo 8 they worked fine for over 5 years.
Best thing is that they are under $20.
Kip2MyLou
I'd greatly appreciate that man. Thanks.
^ Those were the same ones I had in mine and they blew after 6 months. I was kinda disappointed in them. I heard everybody else have nothing but great things about them, so maybe it was just my set. I'm going the lens cover route this time because it's too damn hard to switch out the fogs in these car.
razorlab
5 months? either you got a defective set or you touched them before installing.
Hard to switch fogs? It takes maybe 5 mins? You reach underneath, disconnect, twist and pull and reverse the steps to install. You don't even need any tools other than your hands.
Kip2MyLou
You have to take out the entire headlight assembly.. Unless I've been doing it wrong.
razorlab
No you don't. You literally do what I outlined above. The fogs aren't even part of the headlight assembly.
Hijinx
I take out my headlight assembly; less hassle as you can see what you're doing.
razorlab
Alrighty, you guys have fun with that.
I know I was able to install mine in under 5 minutes, with zero hand tools and I could see what I was doing the whole time. That is way less hassle than taking the head lights out.
Go from underneath the car.
Hijinx
I can't fit under my car to see anything, or reach in far enough to grab the bulbs.
Hijinx
#33
I've already changed mine; it's easier for me to remove the headlights. *shrug*
stuntdoogie
#36
Check pepboys for tje yellow bulbs that's where I got mine $24.99
JPGC
#37
The headlights take like 30 seconds each to remove and reaching up from under is easy too! Both ways are easy, lol
i was realllly gona do the photos but after pulling the headlight out (1 min tops) its jus so easy to change the bulbs that way there is no point in screwing around trying to remove the fog assembly. i was going to go yellow film originally which is why i wanted to pull the fog out, but i just went silverstar everywhere. more adult appearance in my mind. sorry man!
Kip2MyLou
#40
No problem man. Mind posting what yellow fogs you purchased?
