Forscan
MRX330
Minnesota
What I got from searching was the ability to read codes and change wallpaper. I know about engines not computers.
SFV, So.Cal.
What does it do and why would I need it?
I know very little as well but from what I understand it allows you to change some of the Body Computer settings.
If you refer to this spreadsheet you can see some of the things that have been changed and tested.
Forscan Spreadsheet
MRX330
Minnesota
So Forscan let’s you mess with the cars brain for all the non essential stuff. I was close
SFV, So.Cal.
Yes, very close.
However, only the Body Computer controlled things.
I have never played with it myself.
CarGuy
Daytona Beach, FL, USA
You don't need it but it allows you to change some of the vehicles electronically controlled parameters. It's free software! The only other thing required is an OBDII adapter which can be found starting at $25. With it I was able to add NAV to my 2014 and 2015 FiST. I was able to change parameters to engage Daytime Running Lights in my car. I enabled a reverse gear sound but will likely go back in and turn that off. I enabled the foglights on with low or high beams but haven't confirmed that my settings are correct yet. You would be surprised at all the things it allows you to do. When I'm ready I will upgrade from Sync2 to Sync3 and the Forscan software will allow me to configure the APIM so that my vehicle thinks it is As-built otherwise it wouldn't work. I hope those examples help you to understand all that it can do and peak your curiosity to learn more. Sorry I couldn't be more extensive in my earlier response but I was spending time with my wife on my day off. Happy wife, happy life and I still enjoy being with her. Lol
PunkST
Menasha
Id love to have this enabled on my 16. I drive in the country for work. Extra light mean less chance of deer strike
danbfree
Tigard, Oregon, USA
More like $10 for a Bluetooth adapter and to me the best thing is removing the stupid sound processing that completely kills audio quality.. I also enabled the ST splash screen, added the worthless climate control tab for fun but you can also disable/reset TPMS and change your tire size to keep the speedo/odometer accurate.
MRX330
Minnesota
It would be nice if all these settings could be changed without using Forscan
SFV, So.Cal.
It was once before.
However, dealerships were later instructed to only program the BCM to as built settings.
